Author Topic: Power steering Gearbox Question...  (Read 996 times)
Offline elevenssc
« on: December 18, 2009 - 03:51:13 PM »
With the car on jackstands and the engine and tranny out of the car, the input shaft to my power steering gearbox on my 1970 Barracuda has about 20deg of free play in it.  (I can trun the steering wheel aout 20 deg before the gearbox/wheels move).  Reading the manual. I get the impression that the output to the pitman arm is what is used to adjust the freeplay out of the gearbox.
Any Ideas?  Can the input freeplay be adjusted out too?  Do I need a new gearbox?  If so, where do you recommend I get another one?
Now's the time to replace it if I need to...
Thanks
Offline farmboy70
Re: Power steering Gearbox Question...
« Reply #1 on: December 18, 2009 - 06:19:38 PM »
Is this movement with the column in ? If so the coupler pot at the end of the column has been known to wear out. Parts are available at most Mopar dealers for this.
Follow the intructions in the service manual for the adjustments. Do not go too tight the car will tend to stay were the wheel is put.
« Reply #2 on: December 18, 2009 - 07:14:53 PM »
I have play like that too. I'm replacing it with a Firm Feel unit. I've never liked the 'pinky finger' steering of the original box. I figured even if I could adjust out the play, I'd still have steering I don't like. :2cents:
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #3 on: December 18, 2009 - 07:18:50 PM »
what kind of unit are you replacing it with
72rtchallenger
what happens in the garage
stays in the garage
« Reply #4 on: December 18, 2009 - 07:25:10 PM »
A FFeel stage two.
  • 72 to 70 clone
    • cardomain
« Reply #5 on: December 18, 2009 - 07:29:41 PM »
A FFeel stage two.
not to hijack the thread but is it alot different then the original as I don't like the one finger steering either
72rtchallenger
stays in the garage
« Reply #6 on: December 18, 2009 - 07:48:00 PM »
I can't tell you yet. It's on order and I don't have it. From going through other threads on steering, most seem to like level 2, some prefer level 3 - a little stiffer yet. Steer and gear also offers similar equipment, I just heard more positive responses about firm feel so I went with them.  Others that have already installed one of these aftermarket 'tweeked' boxes might chime in...
« Reply #7 on: December 19, 2009 - 01:27:49 AM »
I have installed 2 stage 2 boxes in the last 3 months  & they definatly improve the feel , ! came from FF, the other from Steer & Gear , Steer & Gear was faster & cheaper customer service was awesome with both
