Author Topic: Challenger Reverse Light Wiring  (Read 4850 times)
Offline ghjedi
« on: December 20, 2009 - 01:23:33 PM »
Hello,
Can someone help me with the wiring for the reverse light in the dash?  I have a 4sp manual and just got the light (the original was missing altogether) and of course there are no instructions.  I'm not sure where the wire should go to and any help is much appreciated.
1 of 1 1972 Challenger 440 4sp Convertible Blue GB2
2012 Challenger R/T Classic Blue Streak Pearlcoat
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Challenger Reverse Light Wiring
« Reply #1 on: December 20, 2009 - 01:42:27 PM »
the wires that run to the neutral switch come up and plug into the bulk head on to the fire wall and there is a black wire with a white stripe.I believe its that one,when I found my wiring to the neutral switch the end that plugged in to the bulk head had an extra wire black/white that had a plug on the end and I plugged mine in there,,here is a web site with wiring diagrams
http://www.mymopar.com/index.php?pid=28
72rtchallenger
what happens in the garage
stays in the garage
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: December 20, 2009 - 07:25:06 PM »
should be white with black on the dash side to tap into. or if you dont want tsplice into their. just go to the rear harness connector and you will see the white then goes to purple wire in the rear harness
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #3 on: December 21, 2009 - 01:39:18 AM »
the way the factory did it was to run through a seperate grommet above the gas pedal , the reverse harness plugs into the bulkhead & goes down to the tranny but there was a seperate pigtail at the bulkhead connector to plug into
  • 72 to 70 clone
    • cardomain
« Reply #4 on: December 21, 2009 - 06:18:31 PM »
:iagree: yes that is how I did mine
72rtchallenger
stays in the garage
Offline ghjedi
« Reply #5 on: December 29, 2009 - 01:46:09 PM »
Thanks!  Do you know if this interior reverse light wire is the same one for the rear reverse lights? I have a 4 speed manaul and naturally, these lights do not come on when I put the car in reverse.
« Reply #6 on: December 29, 2009 - 04:43:53 PM »
They should....Check your reverse switch and the wiring to it.
  • 72 to 70 clone
    • cardomain
« Reply #7 on: December 29, 2009 - 06:30:07 PM »
:iagree: and check your linkage to make sure its in reverse properly
72rtchallenger
stays in the garage
