Author Topic: Cleaning dash harness, what should i use?  (Read 1088 times)
Offline lime73
« on: December 20, 2009 - 02:17:43 PM »
I have removed my dash harness to repaint dash. I would like to clean up my dash wiring harness since i cant afford to buy a new one($599.00 a little steep).  My question is what should i clean the harness with , I don't want to damage or further dry out any of the wires or connections. Just soap and water?  Thanks and Happy Holidays to all
Offline CHL2T
  • Handle it, man!
Re: Cleaning dash harness, what should i use?
« Reply #1 on: December 20, 2009 - 10:51:58 PM »
I'm assuming you just mean the dust/ dirt that has acumulated on the harness, so I would say to use some sort of cleaning wipes followed by a wipe down with a damp rag. then you can freshen up the wrap from there with some new stuff.
I would stay away from the full on washing with soap and water  :2thumbs:
« Reply #2 on: December 20, 2009 - 11:44:06 PM »
I've cleaned lots of stuff like weatherstrip, plastics, including wires with mineral spirits with no apparent harm but you may wipe off some ink printing.
Offline FY1 RT SE
« Reply #3 on: December 23, 2009 - 11:46:59 AM »
Get a big bucket and soak it overnight using ORIGINAL Dawn dish detergent.
To do it correctly, the wrap should be removed, then soaked, dried and then rerapped.
Offline 72cudamaan
« Reply #4 on: December 23, 2009 - 01:35:26 PM »
Electronic cleaner in a spray can also works really good.  And it evaporates quickly.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 73EStroker
« Reply #5 on: December 24, 2009 - 06:02:02 PM »
Use a product called Electrosol. Should be available at electrical parts wholesalers or most hardware stores. Doesn't damage anything electrical except keep it away from electronic circuit boards.
Barry (Salmon Arm)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #6 on: December 27, 2009 - 03:18:26 AM »
To clean contacts you could use some Deodxit D5.  It works wonders on my vintage hi fi gear and tube amps.
