Author Topic: Speedo trouble  (Read 1307 times)
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
Speedo trouble
« on: December 23, 2009 - 11:16:09 AM »
Just wondered if I did something wrong.
 I just installed a new gauge panel and noticed that when I go faster then 70 my speedo tends to go a little crazy. Anyone tell me why it might be doing this. Once I drop below 70 the speedo smooths out and seems to be pretty right on. Is the cable loose? What might cause this?  :eek4:
Re: Speedo trouble
« Reply #1 on: December 23, 2009 - 12:10:05 PM »
Could be the guage sticking or the cable could be binding , you can remove the inner drive cable & coat it with lubriplate / white lithium grease
Re: Speedo trouble
« Reply #2 on: December 23, 2009 - 12:45:28 PM »
sounds like a plan I will try that. Because I just changed it and the last one didn't do it. I was worried it was a bad speedo.  :thumbsup:
Offline 72cudamaan
Re: Speedo trouble
« Reply #3 on: December 23, 2009 - 01:34:11 PM »
 I agree with Neil.  Even better, take the cable completely out, spray some lithium grease into the cable housing and chuck the cable into a drill.  Run the drill slowly so that the cable will actually pull the grease all the way through it.  You must run the drill in the proper direction depeding on which end you connect to.  The cable is wrapped so it will act like a screw with threads.
If I cant fix it, it's broke
Andy  (phukker whither)
Re: Speedo trouble
« Reply #4 on: December 23, 2009 - 10:57:58 PM »
Offline shadango
Re: Speedo trouble
« Reply #5 on: January 06, 2010 - 12:12:02 PM »
When yours goes crazy at 70, does it make a loud whirring noise too?
I have the same symptoms you have plus that noise.....
Re: Speedo trouble
« Reply #6 on: January 06, 2010 - 01:08:13 PM »
the noise is Usually in the cable but can be in th eguage as well , try lubing the cable first
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Speedo trouble
« Reply #7 on: January 08, 2010 - 07:38:16 PM »
72rtchallenger
what happens in the garage
stays in the garage
