Author Topic: Why is it so hard to find a gasket for this?  (Read 4497 times)
Offline Glennster
« on: December 25, 2009 - 07:56:57 AM »
 I had two auto parts stores order a gasket for this, they both got the same under sized rubber ring. I told them it was for a 72, 340......The Fel Pro package said 68 - 85 V8.
  I'm about ready to make my own, but I couldn't get a gasket material that's thick enough. One guy tried to talk me into cork, but I thought that would not hold up.
  Any ideas???
THANK YOU &
MERRY CHRISTMAS ! ! ! ! ! ! !
Offline farmboy70
Re: Why is it so hard to find a gasket for this?
« Reply #1 on: December 25, 2009 - 08:21:52 AM »
Was the part number 70522? That is what I came up with on Felpro site for oil filter adapter.
Offline Glennster
« Reply #2 on: December 25, 2009 - 09:16:22 AM »
I don't know, I already returned it.............
« Reply #3 on: December 25, 2009 - 09:25:43 AM »
What year & CID is your block? 340 stopped in '73 ...appears to be different for 360's
1968 DODGE DART GTS 5.6L 340cid V8 (P) : Engine : Oil Filter Gasket   Price   Core   Total   Advice
FEL-PRO Part # 70078 More Info
1970 DODGE CHALLENGER T/A 5.6L 340cid V8 (J) : Engine : Oil Filter Gasket   Price   Core   Total   Advice
1972 DODGE CHALLENGER 5.6L 340cid V8 (H) : Engine : Oil Filter Gasket   Price   Core   Total   Advice
1972 DODGE B300 VAN 5.9L 360cid V8 (F) : Engine : Oil Filter Adapter Gasket   Price   Core   Total   Advice
FEL-PRO Part # 70522
1973 DODGE CHALLENGER 5.6L 340cid V8 (H) : Engine : Oil Filter Gasket   Price   Core   Total   Advice
1974 DODGE CHALLENGER 5.9L 360cid V8 4BBL (L) : Engine : Oil Filter Adapter Gasket   Price   Core   Total   Advice
FEL-PRO Part # 70522 More Info
1976 DODGE D100 PICKUP 5.9L 360cid V8 2BBL (F) : Engine : Oil Filter Adapter Gasket   Price   Core   Total   Advice
1980 DODGE D150 PICKUP 5.9L 360cid V8 4BBL (T) : Engine : Oil Filter Adapter Gasket   Price   Core   Total   Advice
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: December 25, 2009 - 12:04:34 PM »
call your local dealer they are still avialable from mopar, the outer gasket and the center bolt gasket, if you have trouble let me know and I can look it up for ya,
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #5 on: December 25, 2009 - 12:55:06 PM »
is this the one you need,it was left over out of one of my sets,I used the one that was just a ring,,made like this but didnt have the center,but I thought either would work but I am not sure,,yours if you want it
« Last Edit: December 25, 2009 - 05:52:49 PM by 72rtchallenger »
72rtchallenger
what happens in the garage
stays in the garage
  • 72 to 70 clone
    • cardomain
« Last Edit: December 25, 2009 - 04:56:51 PM by 72rtchallenger »
72rtchallenger
stays in the garage
« Reply #7 on: December 25, 2009 - 05:35:01 PM »
You have the angel adapter?..... Can get through any MP dealer.
MOPAR - Oil Filter Adapter Set
To service P5249624
$8.95
http://chucker54.stores.yahoo.net/oilfilad.html
« Reply #8 on: December 25, 2009 - 06:23:53 PM »
It will show up in a package like this.
Offline Glennster
« Reply #9 on: December 25, 2009 - 07:49:23 PM »
72rtchallenger,
  THANK YOU very much for the offer, but that's not the one I need.
The one you showed on ebay is what I need.
I'm glad I came here to ask the question, it looks like there are small gaskets that go in the center. I over looked the little center gaskets. THANKS!!!!!!
Bullitt,
  I do not have the angle adapter. I'm not sure if I could even get one in there with the Hooker headers. There's room to get the short fat oil filter in there, I can remove/install it from up top only.
THANK YOU for the help Gentlemen!!!!!
I hope everyone had a GREAT Christmas ! ! ! ! ! ! ! !
Offline tvacuda340
  • F1A procharger 422 small block
« Reply #10 on: December 26, 2009 - 01:00:44 PM »
hi
i got the same problems i had to us 2 gasket to make it seal probber
Offline Glennster
« Reply #11 on: December 26, 2009 - 05:32:13 PM »
 The plate/adapter off my 340 was pulled down so far it would take 2 or 3 gaskets to get a seal. I was going to beat it back to it's original form, but I took the one off my 318 instead. It was in great shape.
  I checked to make sure there was room for the threaded nut to pull it down and I used some stuff called YAMABOND on both sides of the gasket.
 This stuff is a great sealer, I used it on the tranny cases on my motorcycle (Honda VTX, 1800cc V Twin), these cases are machined so well that they do not use a gasket, just a sealer like this is used. I have no leaks and I use a synthetic oil.
