Good luck with that Handm!
Before getting to the car today I stopped by Kragen and bought a dual ballast.
I checked both the single ballasts and they both checked out. I had a loose wire as it turned out, and 2 more wires that were attached haphazardly. The wires were stretched and would have come apart again if I merely reattached them.
I installed the dual ballast, mounting it in a good spot that would allow the wires to be attached correctly. Then I soldered the wires that did not have connectors on the prongs. Then I reattached the 4 wires after cleaning the contacts with deoxit.
The car fired right up faster and more powerfully than it ever has. It's always been a sluggish starter. Now it roars to life.
So it fixed that part of the problem. It still intermittently starts in park. I can live with that though until I gigure it out. Any ideas? Starter safety switch or maybe the shift linkage? Tody for the first time the trans ground like it was half in gear when I tried starting it.
Thanks everyone for the help!
