Author Topic: More caliper Q`s  (Read 859 times)
Offline torredcuda
  • Epping NH joined 11/23/03
More caliper Q`s
« on: December 27, 2009 - 05:07:36 PM »
Ok,I have two different length caliper pins that came with mt `72 setup and need to know which one is correct.Also I need to find some positioners as I only have two for the `72 setup and none for the `73 setup which is going on the Duster.The `73 set up also has all four of the shorter length pins,I`m confused again!  :pullinghair:  Also on the `72 set up the inner(larger bushings) only have a shoulder on the outside while the new bushings I bought have shoulders on both sides?
« Last Edit: December 27, 2009 - 05:09:54 PM by torredcuda »
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Re: More caliper Q`s
« Reply #1 on: December 27, 2009 - 05:31:38 PM »
Positioners? Do you mean these?  They are for the longer pins. Seen on 70-72's
http://www.n96airgrabber.com/proddetail.asp?prod=DBR%2D001
Pins are still available if you want to replace them. NAPA also sells the rubber hardware. In fact complete calipers.
http://www.rockauto.com/catalog/moreinfo.php?pk=904748
http://www.napaonline.com/Search/Detail.aspx?A=UBP82202W_0197987892&An=599001+101971+50020+2020006+11011+599999+109999+59999+2999999
Offline LAA66
« Reply #2 on: December 27, 2009 - 07:53:46 PM »
 I know the 70 has the longer shoulder.  How many years afterwards??
 The bushing retainer clips (if original) should tell which one fit your year. Just a slight compression on the clip when tightened, otherwise they will break at the pivot.
 I hear the clips are difficult to find these days. Do you know a source? :popcorn:
« Reply #3 on: December 27, 2009 - 10:18:41 PM »
There are 2 types of clips. The flat faced one's and the one he shows that has a cupped/domed area. I posted the clips already that are repro'd.
Were they not the ones?
Offline LAA66
« Reply #4 on: December 27, 2009 - 10:50:55 PM »
 I swapped out one caliper way back when and have both cupped and flat. I think the flat clips look to be 70 vintage. Nice pieces, "UP" imprint and all.
Thanks for the link.  :thumbsup:
 My thought is the double flanged pin bushings were used 73 up instead of the clips as that would hold them in place. :clueless:
Offline torredcuda
« Reply #5 on: December 28, 2009 - 06:52:16 AM »
That was what I was thinking-the `72 has the longer pins and the positioners with the one flanged bushing and the `73 has the shorter pins and no positioners and the double flanged bushings,yes?
If so anybody have a couple  spares to sell me instead of me paying $35.+shipping for a set.  :22yikes:
« Last Edit: December 28, 2009 - 06:54:40 AM by torredcuda »
Jeff
