Author Topic: brake pedal goes to the floor??  (Read 7185 times)
wagesofsin
Re: brake pedal goes to the floor??
« Reply #15 on: December 28, 2009 - 07:14:30 AM »
New master cylinder or one that has been bone dry needs to be "bench bled"...
Is this the situation and did you do it?
i knew i forgot to ask something!!
 :banghead: :smilielol:
« Reply #16 on: December 28, 2009 - 08:13:33 AM »
Filled and bled my brake lines today. Once I fired up the car my brake pedal went right to the floor?? Dosconnect my vacum from the booster and it obviously didn't, but still no brakes?? What could be the problem?
I don't understand that statement.   Do you mean that when you press the brake pedal it goes to the floor?, and returns.        Or does it literally go to the floor on it's own?
Offline BIGSHCLUNK
« Reply #17 on: December 28, 2009 - 09:22:48 AM »
When I said to bench it I did mean while on the car (sorry). I'm thinking between al the commentary here you should have everything you need to geter' done.  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline kmyles
« Reply #18 on: December 28, 2009 - 03:19:54 PM »
Goes to the floor on it's own...literally :faint:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
« Reply #19 on: December 28, 2009 - 03:47:50 PM »
Don't see how that is even possible.... Tell the whole story of what has been done & maybe someone can zero in on the culprit.
« Reply #20 on: December 28, 2009 - 05:42:25 PM »
I have seen bad brake boosters do that before. A diaphram colasps or something
Offline kmyles
« Reply #21 on: December 28, 2009 - 06:32:39 PM »
Any idea where I could get a brake booster for a good price??
_________
Kevin
wagesofsin
« Reply #22 on: December 28, 2009 - 06:39:00 PM »
i got mine from  :puke: autozone
here it is
http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?displayName=Brake+Power+Booster&currentPage=1&categoryDisplayName=Brakes+%26+Traction+Control&navValue=14400143&itemId=143-0&parentId=44-0
and it does work perfectly, mind you i didnt care that it wasnt factory, i just wanted to stop.
advance has a similiar deal
« Reply #23 on: December 28, 2009 - 06:40:56 PM »
You can get a re-manufactured unit from just about any parts place for about $100 but the finish will be rough gray....OR you can send it to http://boosterdeweyexchange.com/ & get a correct finish along with a rebuild for a few more dalla
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #24 on: December 28, 2009 - 08:20:59 PM »
so when you unplug your vacume with the car running does the pedal come back up? and are you pulling vacume from the normal spot on the intake?
72rtchallenger
what happens in the garage
stays in the garage
Offline kmyles
« Reply #25 on: December 28, 2009 - 10:07:18 PM »
Yes when I unplug it the pedal comes back up. I am pulling the vacuum from the spout on the back of the intake.
_________
Kevin
  • 72 to 70 clone
    • cardomain
« Reply #26 on: December 29, 2009 - 12:32:12 AM »
I would try bleeding it again and make sure it has plenty of pressure pushing out the air and fluid out the bleeders,,if that doesn't solve it you may have a bad booster ,,if your not getting pressure out the bleeders when you bleed that may be the new master cylinder,,but if has plenty of pressure when bleeding it must be the booster,,but i have never seen one with the symptoms you describe,,so it is strange but someone did state here they have run into a booster doing what you describe ,, i know it sucks to change the booster with the seats installed and everything else in the way,,hope you get it solved
72rtchallenger
stays in the garage
Offline Aussie Challenger
« Reply #27 on: December 29, 2009 - 01:05:36 AM »
  One other possibility is if there is no free travel at the brake pedal or between the booster and the master cylinder. Did you check the clearance on the new master cylinder before installing?   :bigsmile:
