Author Topic: Valve cover breather?!?@%^&!  (Read 2359 times)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« on: December 27, 2009 - 09:06:34 PM »
318 motor, 4 bbl weber/holley carb and an edelbrock intake with a K&N air filter and stock valve covers.
I am running filters in the breather holes of the valve covers.  Oil smoke wafts out of both of these, particularly the one on the passenger side.  Needless to say this has wiped out my air cleaner and going to coat my freshly cleaned up engine in oil. I actually smell like oil if I drive the car for too long.
What are my options to properly vent the valve covers and not pump oil into the air?
Here is a picture.  I have cleaned and detailed the engine since then and I want to keep it nice.
Offline HemiOrange70
Re: Valve cover breather?!?@%^&!
« Reply #1 on: December 27, 2009 - 09:17:09 PM »
I would think of adding baffles to your valve covers and I use a breather cap on one side and a pcv valve connected to the carb on the other-no problems
http://s1021.photobucket.com/albums/af340/hemiorange70/?albumview=slideshow
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #2 on: December 27, 2009 - 09:18:27 PM »
i couldnt see a pcv valve in pic. and if it doesnt it will help to add
72rtchallenger
what happens in the garage
stays in the garage
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #3 on: December 27, 2009 - 09:37:36 PM »
Thanks guys.  I will get a PCV valve and run it into the carb. The cover on the driver side has a baffel and it does not smoke like the pass side does if at all.
Offline 6packCuda
« Reply #4 on: December 27, 2009 - 09:41:39 PM »
I'll bet adding a pcv valve will solve your problem.
Offline Aussie Challenger
« Reply #5 on: December 28, 2009 - 01:51:54 AM »
  That's what the PCV is for, it directs the excess fumes into the base of the carby for burning in the motor, however under hard acceleration or constant high speed the breather will expel fumes as the PCV cannot pass all the fumes into the motor for burning. On factory setups the breather on the other rocker cover went into the air filter to stop oil vapor contaminating the air and making a mess under the hood.   :2thumbs:
« Reply #6 on: December 28, 2009 - 02:30:19 AM »
PCV is the fix just make sure it runs to the carb base so all cylinders burn off the smoke , hooking to the intake runner will foul 1 plug
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #7 on: December 28, 2009 - 03:52:14 AM »
Thanks guys, I don't have a riser block so inputing it under the carb is out scout.   Should I connect it through the PCV port <in red> or the vapor vent <in yellow>  When I got the car it had the grungy original breather with a tube going to the vapor vent.
« Reply #8 on: December 28, 2009 - 04:20:46 AM »
  I would connect to the yellow port
Offline 6packCuda
« Reply #9 on: December 28, 2009 - 06:34:02 AM »
Yellow one is for pcv. Red is your fuel vapor vent.
Offline IMNCARN82
  • LeDZeP
« Reply #10 on: December 28, 2009 - 08:30:22 AM »
Pass. breather shouldn't have that end for a tube on it.Unless you run a standard air cleaner. PcV normally comes off the Drivers side cover to the yellow vent.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #11 on: December 28, 2009 - 12:46:58 PM »
So I should get a pcv valve for the drivers side, then put the input filter on the pass side?
« Reply #12 on: December 28, 2009 - 12:57:02 PM »
The PCV valve would be on the opposite valve cover from the breather filter. It doesn't matter which is on what side unless you are going for correct appearance.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #13 on: December 30, 2009 - 12:01:46 AM »
I got a pcv valve, grommet, hose, anda  new breather from Napa.  The car runs better than ever and no longer smells like oil.  Thanks for the help!
Offline Glennster
« Reply #14 on: December 30, 2009 - 07:47:10 AM »
 Ian,
  Isn't it great to have these guys to help you through problems? For guys like you and me, stuff like this is a mystery, for the seasoned MOPAR guys on this site, this stuff is a no brainer.
  It's great to have all these good people to assist us rookies!!!
GOOD LUCK with your Chally, keep up the good work!!!
