Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
new engine wont stay running
« previous
next »
Print
Pages: [
1
Author
Topic: new engine wont stay running (Read 1023 times)
guys71cuda
Jr. Member
on:
December 28, 2009 - 04:35:47 PM »
it fires right up but as soon as i let off the key she dies. what could be causing this?
Logged
Moparal
Permanent Resident
Re: new engine wont stay running
Reply #1 on:
December 28, 2009 - 05:02:10 PM »
Ignition switch or ballist resistor
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #2 on:
December 28, 2009 - 06:55:41 PM »
The ballast resistor is a cheap fix, but what ignition system are you running? Stock or MSD or something else?
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
guys71cuda
Jr. Member
Reply #3 on:
December 28, 2009 - 07:35:35 PM »
the ballast resistor was right before pulling the engine in august. its cheap worth a try i guess. i have the stock ignition system.
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #4 on:
December 28, 2009 - 07:39:37 PM »
With a meter or a test light you can check for power to & through the ballast
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Tonefiend
Full Member
'70 Challenger
Reply #5 on:
December 29, 2009 - 02:38:04 AM »
I had the exact same problem a few days ago. Turns out it was a loose wire at the ballast resistor.
Logged
guys71cuda
Jr. Member
Reply #6 on:
January 02, 2010 - 03:55:56 PM »
made sure the wire connections to the resistor were on the whole way. no luck. replaced the ballast resistor. still no luck. what else should i check for. it will keep running with key turned but dies the second i release the key from the start postion. .
Logged
Bullitt-
Permanent Resident
Reply #7 on:
January 02, 2010 - 04:02:00 PM »
There's all the wiring & connectors from the steering column through the firewall bulkhead, any broken wire or bad connection of the run circuit will cause this, & finally the ignition switch itself (lets hope not).
Logged
Huntsville, AL
guys71cuda
Jr. Member
Reply #8 on:
January 03, 2010 - 11:55:33 AM »
how would i checkthat the ignition switch is working properly ?
Logged
73EStroker
Sr. Member
Reply #9 on:
January 03, 2010 - 02:01:16 PM »
Checkout what Bullitt says. A little background is that there are two wires that come from the ignition switch out to the ballast resistor/coil. One is 12V to the resistor with the ignition in the 'on' position. The other is 12V direct to the coil (ie. bypasses the ballast resistor) in the 'start' position only. Your engine is running on this bypass circuit only. Trace the wires back from the ballast resistor to the firewall. With the wires identified place the ignition switch just in the 'on' position then look for 12V (with a meter or test bulb) at the bulkhead connector for the wire that goes up to and through the resistor. I think that is the dark blue wire. If no voltage at the bulkhead then go inside the cabin and trace back to the ignition switch via the plug in connector on the steering column. ( times out of 10 it is a bad connection at the bulkhead. There are new terminals available for the bulkhead which I recommend you change out. I replaced all of my connectors (male and female) at the bulkhead during my resto and no problems so far. Also did the light relay wiring to take the large loads away from the bulkhead and the light switch.
I know electrical is what most people hate doing but my motto is if you are down there trying to fix it get a wiring diagram, study it for a while then do it right and do it once. Hope this was useful.
Logged
Barry (Salmon Arm)
Chryco Psycho
Administrator
C-C.com Guru
Reply #10 on:
January 03, 2010 - 03:41:07 PM »
I have seen the dist pick up coil fail as well , the engine will stat & after a minute or so the coil will heat up & quit
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
