Author Topic: ideal 440 carb?  (Read 718 times)
Offline challngd73
ideal 440 carb?
« on: December 28, 2009 - 05:36:13 PM »
Just as the title states.. I have a 750 eddy on my 440 now, and I am looking for a change.  I have no idea if there are any mods in the motor as it sits.  I know it has an accel coil, torker intake and headers.  This is my first mopar, so Im not overly familiar with what they sound like stock.  It seems to have a lobe to it, but Maybe they all sound like that.  Anyways, i will eventualy be adding a stroker kit and better heads, and I only want to buy one carb.  I have been looking at the proform carbs, and i was thinking 850-950.  Whats the big difference between their street series and race series?  any help or other suggestions are appreciated.
Re: ideal 440 carb?
« Reply #1 on: December 28, 2009 - 07:02:30 PM »
You are sniffing down the right track.   :thumbsup:
Yeah, it sounds you are more than stock for sure. I have an 850 street series on mine, but just because that was as big as they went with a choke plate. It sounds like with your mods you might want to go bigger, but for me I didn't want to be choke less in the cold weather here.   :sadwavey:
Offline challngd73
Re: ideal 440 carb?
« Reply #2 on: December 29, 2009 - 12:46:44 AM »
outstanding, thanks for the reply.
Re: ideal 440 carb?
« Reply #3 on: December 29, 2009 - 03:25:17 AM »
I have consistant used the Proform Race series carbs & doubled the CI so if you are looking at a 500" stroker at least a 950 CFM , 1050 is also possible if you are looking at a serious build with some heads that flow a lot of air
Offline challngd73
Re: ideal 440 carb?
« Reply #4 on: December 29, 2009 - 09:09:57 AM »
great, thanks.  Just one question, if im not going to do the stroker kit for a season or 2, wont a 1050 cfm be too much until its stroked?  will it cause drivability issues until I stroke it?  would 950 cfm be a comfortable medium for both combos?  thanks again.
Re: ideal 440 carb?
« Reply #5 on: December 29, 2009 - 10:55:35 AM »
The 950 will definatly work better on the smaller / possibly stock engine but may limit the top potenial of the larger stroker build . there is really no good solution for this except EFI which would adjust for the displacement difference , I have not tried to run a 1050 on a mild 440
