Author Topic: 383 build  (Read 2138 times)
Offline Bart
383 build
« on: December 29, 2009 - 11:52:11 AM »
Well, I got my 383 back from the motor shop, new Diamond pistons, cam 284/296, Lift .507/.510, so now I need a oil pump and pan. Reading about this is confusing  to me, any help will be appreciated. Is this true?
"If you are useing an HV pump. It will have a tendency to suck the pan dry depending on all the clearance issues in your engine build. High rpm's and a stock pump with the engine all in spec makes for good flow"
Is the 402 pan the one I want with windage tray?
Stroke is stock
Going with Edelbrock heads and getting them cut to 80cc this should give me about 10.2:1
Regards,
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Offline Bart
Re: 383 build
« Reply #1 on: December 29, 2009 - 03:55:42 PM »
So after more research is the 402 pan what I need, anyone?
 :clueless:
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Re: 383 build
« Reply #2 on: December 29, 2009 - 05:59:28 PM »
Bart, get the 6 pack/  hemi pan and the 3/8ths pickup tube.   You do not want to use the 402 4 qt pan, it will not be enough with the hv pump
Re: 383 build
« Reply #3 on: December 30, 2009 - 12:01:29 PM »
the big blocks have no real oiling problems as long as the pan has oil in it , I would use the Hemi 6 qt oil pan & tube from Mancinis & the HP melling oil pump not the HV pump
 with the heat loss to the alum heads you will have an effective 9.2:1 compression ratio so it should run on reg fuel
Offline Bart
Re: 383 build
« Reply #4 on: December 30, 2009 - 01:30:15 PM »
Thanks but why do I want the HP pump vs the HV, I put the Hemi cam in which has a smaller oiling hole which should be more presure on the top end.
Also what about a windage tray, Yes/No?
 I figure with 4.310 bore stock stroke 3.375, 80cc (head cut down) and 0 deck should be about 10:1.
Regards & thanks
Bart
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Re: 383 build
« Reply #5 on: December 31, 2009 - 04:22:27 AM »
the HP pressure pump will increase the pressure but not move 30% more volume , this will prtect the engine without sucking the oil pan dry & starving the brgs ,
 Windage tray definatly yes
Offline Bart
Re: 383 build
« Reply #6 on: January 05, 2010 - 03:14:43 PM »
Just want to say Thanks to CP for calling me and advising me about my engine build.
Thanks CP..... :cheers:
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Re: 383 build
« Reply #7 on: January 05, 2010 - 03:52:23 PM »
Anytime Steve  :2thumbs:
 I would post my phone # here but I doubt I would ever get anything else done , BUt I will take time to call any member here if I can help  :crazy:
Offline Cuda Cody
  • Vancouver, WA
Re: 383 build
« Reply #8 on: January 05, 2010 - 04:48:53 PM »
CP's the BEST!   :worshippy:  But if anyone has been here day they already know that.
