Author Topic: Throttle cable for a 318?  (Read 4607 times)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« on: December 30, 2009 - 12:04:55 AM »
My throttle cable is toast!  Today I brought the car by my buddies house. He helped me with some tuning issues.  One of the tings we did was to adjust the throttle cable. Unfortunatly it was frayed and we lost the end plug down into a hole between theintake and head.
So whats the best throttle cable and end, and the best place to get it?
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Throttle cable for a 318?
« Reply #1 on: December 30, 2009 - 12:44:33 AM »
throttle cables can be found,,I would be worried about the piece that fell between the head an intake,,if it falls under a valve it can hurt the valve and if it falls down past the valve it will fall on top a piston and cause damage to the piston an cylinder wall,,I may have read wrong what your saying but you want nothing dropping down to moving parts  :2cents:
72rtchallenger
what happens in the garage
stays in the garage
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #2 on: December 30, 2009 - 01:03:24 AM »
It's not near any moving parts, it's in a void between the intake manifold, block and head.
  • 72 to 70 clone
    • cardomain
« Reply #3 on: December 30, 2009 - 01:28:35 AM »
I dont know the company but here is a place that sells one,,but dont know there products
http://www.jacksautoparts.com/catalog/fuel.html
72rtchallenger
stays in the garage
Offline Glennster
« Reply #4 on: December 30, 2009 - 07:52:51 AM »
Ian,
  I've got one that came off my 318. Just get me your address and I'll UPS it to you. Maybe I should send you a picture of it first, let's make sure it's OK for your car.
  Can you say FREEBIE ?!?!?!
  I ordered some stuff from Jack's, I am NOT impressed so far. I placed the order on the 22nd of this month, the parts were in stock according to Jack. I still do not have the parts. He did not bill my credit card, so that's OK. I called him twice yesterday, I asked him if the parts shipped, he said he would call me back both times I spoke to him.......So far, no return call.
  I ordered 12 header bolts from Mancini Racing, Art said they had them. Then he called back an hour later to tell me they could only find 8 of the 12 they THOUGHT they had.
  I REALLY like Mancini, that's the kind on communication I appreciate ! ! !
« Last Edit: December 30, 2009 - 08:02:25 AM by Glennster »
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #5 on: December 30, 2009 - 10:54:36 AM »
Glenn thanks!!  Check your email I can use it!   Check your email!   :cooldancing: :bananasmi :worshippy
Offline Glennster
« Reply #6 on: December 30, 2009 - 02:22:06 PM »
Got it !!!!
Will ship TODAY!!!!
It's nice to be the one helping.......I've had so many people help me, now I can give back a little!
Offline Glennster
« Reply #7 on: January 01, 2010 - 09:29:18 AM »
I did get a call back from Jack's on the 30th, they said the parts would ship that day...............
Offline Glennster
« Reply #8 on: January 05, 2010 - 09:18:30 PM »
 My delivery from Jack's showed up today. I got a windshield washer bottle and a CHALLENGER emblem for the front fender....
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #9 on: January 07, 2010 - 09:11:41 PM »
Glenn the cable arrived today!   :bananasmi  Thank you!!!!  :)
 compared it side by side with the old one and they are identical.  I am hoping to have some time Saturday to put it on.
 :cooldancing:
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #10 on: January 07, 2010 - 10:08:33 PM »
Here is a pic of the old "rigged" cable that let go.
Offline tactransman
« Reply #11 on: January 08, 2010 - 01:04:42 PM »
Good job guy's!!!  You gotta love it!  :2thumbs:
Terry-tactransman
Union, Mo.
Offline Glennster
« Reply #12 on: January 08, 2010 - 08:39:26 PM »
Glad to help!
Keep working on that BAD A$$ Challenger!!!
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #13 on: January 08, 2010 - 10:01:31 PM »
Glad to help!
Will do!
Whats that piece of metal taped to the cable.  Looks like a tool for working the clip?
Offline Glennster
« Reply #14 on: January 09, 2010 - 10:00:50 AM »
I should have taken a picture of that sucker before I took it out.........
That is stuck through the plastic keeper clip that holds the cable to your fire wall. You'll have to snake your way upside down under your dash to remove that thing from the cable that is in you car now. You won't be able to get the original cable out until you remove the little metal piece.
  Once it is out, you can use a small to medium size pair of channel locks to squeeze/compress the plastic clip that holds the cable to the fire wall. You need that type of tool with open jaws to get the right angle, pliers won't work. It also helps to have a second person pulling gently on the cable from the front of the car. It's hard to squeeze the clip and push it out the front of the fire wall at the same time.
 GOOD LUCK!!!
