Author Topic: bolt-in new E-body Dana 60 options  (Read 1468 times)
Offline hemi68charger
  • Charger Power!!
    • Houston Mopar Club Connection
« on: December 31, 2009 - 10:37:54 AM »
Hey gang..
Trying to help out a friend who's building an e-body R/T convertible clone. Can anyone let me know a list of companies that can build up a Dana 60 for an e-body? Buying new is one option. I'm currently looking in the used parts section of this and other boards...
Thanks...
Troy
'69 Daytona 426 HEMI-727
'70 Superbird 440 - 4speed
Re: bolt-in new E-body Dana 60 options
« Reply #1 on: December 31, 2009 - 11:16:47 AM »
Cass @ Doctor Diff in Montana would be the frist choice
 Strange , Mark Williams will also build a diff to spec , Mark Williams will have a superior product but neither would break in a street car .
 I have grabbed a diff out of a 70s ford truck with a clutch sure grip & the ratio I wanted for less than $100 then ordered axles for around $500  & housing ends for around $100 & brgs for $100  & then get the housing narrowed for about $275
Offline Katfish
  • 70 Challenger
« Reply #2 on: December 31, 2009 - 12:23:55 PM »
Not cheap, but very nice work and service.
http://www.doctordiff.com/?page_id=5
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: December 31, 2009 - 01:25:50 PM »
DTS.  you can buy an E-body drum to drom with all new parts strange axles, New brakes, posi, gear ratio uptu 4.56 i believe for around 2600.00
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline shaker71
« Reply #4 on: January 01, 2010 - 11:32:16 AM »
Offline vert
  • Looking good, Billy Ray! Feeling good, Louis!
« Reply #5 on: January 22, 2010 - 09:44:12 PM »
Chryco, That Ford unit has no provision for mounting a snubber does it?
71 Barracuda | Hemi idling | Hemi Dyno pull
« Reply #6 on: January 22, 2010 - 09:51:20 PM »
No it doesnt, but doc differential makes an easy weld kit to mount the bracket. Takes about 10 minutes. Not expensive either.  3 round stock cut on the correct angle and tapped on the other side for the mount, bolts are included
