the Eddy Performer intkae is the worst intkae to use , it will cost you power over using the stock Iron intake , Weiand makes the Stealth & Action + that may be low enough to use the other option is the Aluminum M1 Mopar intake but the original low profile version has been discontinued in favor of the RPM intake which is too high to use so you need to find the older version
