Author Topic: leaky carter 2bbl  (Read 1660 times)
Offline guys71cuda
leaky carter 2bbl
« on: January 03, 2010 - 11:59:55 AM »
can anyone post a picture of what the correct mounting gasket is for a factory two bbl. is?
Offline 67vertman
  • Member since 9-23-2005
Re: leaky carter 2bbl
« Reply #1 on: January 03, 2010 - 01:47:22 PM »
I don't have any pictures, but it is about 1/2 inch thick and has brass sleves in each of the four holes.
Where is your carb leaking from?  Do you have a vacuum leak or gas leak?
Offline guys71cuda
« Reply #2 on: January 04, 2010 - 01:22:42 AM »
its a gas leak. the leak only became present after seperating the carb and the manifold which leads me to believe its the mounting gasket.
« Reply #3 on: January 04, 2010 - 08:17:11 AM »
Base gasket is not a liquid seal.... Possible that the float is stuck open. What all was done to the carb while it was off?
Offline guys71cuda
« Reply #4 on: January 04, 2010 - 11:23:03 AM »
i just removed the carb to strip and paint the intake. i made no changes to the carb whatsoever.
« Reply #5 on: January 04, 2010 - 04:37:29 PM »
A piece of crud could of been loosed when you disconnected & made it's way to the needle valve keeping it open, with any luck you may tap on the carb & get it to pass or blowing compressed air though the fuel line might work.   Worse case get a rebuild kit & give it a good cleaning.
Offline 67vertman
« Reply #6 on: January 04, 2010 - 08:09:39 PM »
I agree, it is more than likley not the gasket.  Dry the carb, disconect the coil and have some one turn it over while you look for where tha leak is coming from.
Offline guys71cuda
« Reply #7 on: January 05, 2010 - 02:30:47 AM »
i did have to replace needle and seat as the original cracked when fuel line began to cross thread. could this be my problem? installed wrong maybe?
« Reply #8 on: January 05, 2010 - 08:11:49 AM »
Good place to start. Did you use any thread sealer? I've started putting Teflon tape on everything.
Offline guys71cuda
« Reply #9 on: January 05, 2010 - 08:52:41 PM »
i used the gas resistant (yellow) teflon tape. the leak is coming mainly from the back. its a pretty bad leak not a drip.
