Right Place?
Author Topic: Right Place?  (Read 140990 times)
Offline RUSTY Cuda
  • One big step foward!
Re: Right Place?
« Reply #180 on: May 27, 2005 - 04:44:29 PM »
STILL messin with the trunk lid, shes way low where the putty is, the edge is also, gotta consult my ole body man before I put a gallon a putty on there! :banghead:
but even with the set backs, it was nice to get some hours in on the car, got the engine block offs on, spun the motor a bit, poured a little oil down thew cylinders & gave it a quick coat of degreaser, she's a bit dirty!
Offline RUSTY Cuda
Re: Right Place?
« Reply #181 on: May 31, 2005 - 08:41:01 PM »
Nasty nasty nasty, started to open up the rear end,not for the squeemish! :ack:
« Last Edit: November 18, 2005 - 09:03:12 PM by RUSTY Cuda »
Offline RUSTY Cuda
Re: Right Place?
« Reply #182 on: May 31, 2005 - 08:44:44 PM »
Bout all I will reuse there is some of the hard ware, after 20 hours in the tumbler w/rust remover(should take 5 or 6) big pieces may still need a little wire wheelin, there in the shine em up stuff tumbling as we speak! ;)
Offline RUSTY Cuda
Re: Right Place?
« Reply #183 on: May 31, 2005 - 08:46:38 PM »
Got the rear end pretty clean, etched it & slopped some por15 on, a TAD better!  ;D Rich.
« Last Edit: November 18, 2005 - 09:04:43 PM by RUSTY Cuda »
Offline Carlwalski
Re: Right Place?
« Reply #184 on: May 31, 2005 - 08:53:08 PM »
Looks great Rusty.  :D :thumbs:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: Right Place?
« Reply #185 on: June 01, 2005 - 10:23:43 PM »
I love this thread!!  Great job as usual Rusty!
Offline mrcuda
Re: Right Place?
« Reply #186 on: June 01, 2005 - 10:27:30 PM »
Nice progress Rusty. :)
Offline RUSTY Cuda
Re: Right Place?
« Reply #187 on: June 02, 2005 - 08:37:10 PM »
Shot some prime on the problem spots on the hood & trunk lid, a coat of epoxy to seal em up & then a couple a coats a high build & a quick spray of guide coat, hope to start sanding sat see how much more work is ahead?  no parts in yet  so I 'm working on the rear backing plates, there pretty nasty but a ton of elbow greese should get em useable! Rich.
Plum6Pak
Re: Right Place?
« Reply #188 on: June 04, 2005 - 07:08:12 AM »
Looks great! You are coming along pretty good Rusty, this thread needs to keep going till the last piece is installed and you drive it to the show! Very inspiring to be sure, I need a bit of inspiration now and again.  :thumbs:
Offline Plum6Pak
  • Plum6Pak
Re: Right Place?
« Reply #189 on: July 29, 2005 - 06:51:48 AM »
Hey Rusty, where are you?  :dontknow:  How's it going, please check in and lst us know you are doing okay and give us an update!  :thumbs:
Offline RUSTY Cuda
Re: Right Place?
« Reply #190 on: July 29, 2005 - 07:07:52 PM »
Hey guys, I'm still alive & kickin, mosty kickin latley, busy season at work,been draging butt a bit this year(I'm not getting any younger & these hot attics are takin there toll) even if I could steal a few hours, I'm either too tired or it's too damn hot,fall is approaching rapidly, there will be some 'cuda time, if i can ever find a few small parts that are holding up the suspension rebuild! (strut rod sleves for one) . but I drive the POS 74 around the hood once in a while just to keep up the spirits! Rich.
Offline Plum6Pak
  • Plum6Pak
Re: Right Place?
« Reply #191 on: July 29, 2005 - 11:37:11 PM »
 :grinyes: :thumbs:
Glad all is well in Rusty land, hope to see some progress reports real soon!!
Offline mrcuda
Re: Right Place?
« Reply #192 on: July 30, 2005 - 05:20:22 PM »
Rusty good to see that you're still alive and kicking. ;D
Offline RUSTY Cuda
Re: Right Place?
« Reply #193 on: August 14, 2005 - 11:22:51 AM »
Finally got a few hours in, nothin great, but a couple more parts ready to go on(if the time ever comes)
Found another rotted part I need, the front mount for the leaf spring the one that bolts to the frame, will post a pic in parts wanted!
well here's the big progress!  ::)
« Last Edit: November 18, 2005 - 09:07:00 PM by RUSTY Cuda »
Offline Plum6Pak
  • Plum6Pak
Re: Right Place?
« Reply #194 on: August 14, 2005 - 01:15:15 PM »
That's still progress Rusty, glad to see it's moving ahead! We all do what we can and sometimes a little bit is better than nothing!  :grinyes:   :thumbs: Looking gooood!
