There be life of a sort in the beast!
Got that switch on after much contortioning of my hand & finger joints, actually didn't happen till I jacked up the car a bit, while it was up I cranked up on the t bar adjusters , still seems a bit low, hope he didn't have slant six bars in there?
Anyway, she cranks from the key now,I took the line off the fuel filter & poured some gas down to the pump & lifted the line & put some in the carb lines, put a tad in the carb, after 3 of those short bursts she ran from the lines!
...........but it sounded like a barrel of rotating bricks
So I redid the firing order, now I'd swear it was pointing straight left, which moves it over 1 post from yesterdays set up, moved em & attempted startup, barley a sputter, moved the timing too & fro all to no avail, now i've run the battery down so I get out the charger, while hangin out I put in a few floor pan plugs & stretched out some more wiring.
Decided to put the wires back where they were after setting #1 again, looks like it's pointing right BETWEEN the 2 posts. Now it fires right up, the barrel O crap noise is gone & the destruction has moved to the valve train area, noticed if I bring up the revs a bit it smooths out, not tapping sounds, just choas!
Anyway decide to get it warm enough to check the thermostat, got the cap off , check the guage, temp is comming up, go back out & flow I did get! boy did I get it!
bout a quarts worth all over my nice clean bay! Did this(starting with cold eng) many times before & you'd just see it start to circulate in the top of the rad, never overflowed like that on me!
Got mr340 on the line & he thinks maybe just timing, I hope so. Anyway bout this time my son comes out to see what all the smoke & noise are about & asks what time are we leaving? I'm like leaving for what........... Him..... Moms birthday dinner!
Well the mad rush is now on to clean up out there & get myself cleaned up, so the timing will have to wait! Got some work booked for a few days so at least wed pm or thurs.
On the home front the dinner went well(& on time) Narrowly avoiding the wraith
but all is well on the home front!
OH YEA, she sure did sound sweet when the revs were up a tad through the half open headers!
Rich.
