Messed with some little things today, went to pick up the header flange gasket & it wasn't in yet, but ordered the plug wires, a spade remover tool so I can change out the bad connector I have on the harness & am getting a price on the entire brake system to see when I can buy.The guy will also press on bearings if I buy the complete set from him, says around 150, bearings seals & the press job, sounds good to me, what yas think.
Anyway i put the one flange gasket i had on & just bolted the other one tight, dang, do I really need a gasket, pretty quiet now!
fixed the oil leak at the sender, checked the rad, she slowly looses the pressure, but no leaks showed up, so I filled the antifreeze & put 15 lbs on it again, slowly drops, but again no leaks show, so I ran the motor , before on revs you could see it pull through the radiator, almost dead center, now nothing?
Now I can actually listen to the motor, still sounds smooth.
Messed with the timing & got the wires seperated for now, no specs in the manuel, just says look at emmissions sticker on the car, don't think I have one?
anyway I left it at top dead center, messed a little each way & didn't seem to make much difference, forgot to take off the vac hose, will do it that way next time, is there a basic starting point I should work from?
ran her out of gas, refilled another 5 gals & last i made a little longer stud for the air cleaner, the one he had grabbed about 2 threads on each end! nothin great, but some little things taken care of, Rich.
Oh yea, I tightened the alt belt, thanks Gio!(well & Greg)
__________________
