Author Topic: Right Place?  (Read 140947 times)
Offline RUSTY Cuda
  • One big step foward!
Re: Right Place?
« Reply #510 on: January 25, 2007 - 03:46:34 PM »
Master cylinder is in, had to rebend those short lines quite a bit to make em fit, wonder if I got the right ones, the one with the nice little loop was pointing AWAY from the proportioning valve! :clueless:
Got some off the shelf plug wire holders & made do for now, can't seem to locate any factory ones? Rich.
« Last Edit: January 25, 2007 - 03:48:22 PM by RUSTY Cuda »
Offline RUSTY Cuda
Re: Right Place?
« Reply #511 on: January 25, 2007 - 03:50:05 PM »
Did manage to get a heater hose bracket off ebay, cleaned that up & put it on, now I need to locate the proper fitting for the manifold & get that black pipe outta there!!!!!!!!! :crazy:
Offline RUSTY Cuda
Re: Right Place?
« Reply #512 on: January 25, 2007 - 03:52:42 PM »
almost have a full set of tail lights ready, I spent more time sanding out the scratches in the back than I did on the fronts! :bricks1:
Trying silicone to glue the rings on, think that will hold up?
Offline RUSTY Cuda
Re: Right Place?
« Reply #513 on: January 25, 2007 - 03:58:29 PM »
last 2 cables for the E-brake came in, got a coat a clear on those, might still have a problem with the front, the round push clips that hold it in, the one on my old is brake is beat up & I'm not sure what happened to the one down under the frame? It might(if I'm really lucky, yea right, still be there? ) :dunno: Rich.
Offline RUSTY Cuda
Re: Right Place?
« Reply #514 on: January 27, 2007 - 06:26:23 PM »
Got the emergency brake cables in today. It actually seems to work! :naughty:
Next time I get a helper( or tudor & I'll be the helper)  :dunno: I can bleed the brakes & have some non emergency stopin power!  :o  Rich.
Offline 74chall
  • Mopar or No Car
Re: Right Place?
« Reply #515 on: January 27, 2007 - 09:22:15 PM »
Rich, you do some awesome work my friend. car is looking great! Few questions! What color gray is that that you painted the calipers etc? Also the front brake lines that go to the master, Inline tube didnt sell a kit for NON power brakes for 72-74 ebodys. So i bought the power brake ones. Is that what you did? I figure ill just have to bend the master cylinder lines down a bit to make them fit or cut them and re flare....
Manual brakes  have shorter lines then the power b/c of brake booster..get me?  :clueless:
Offline RUSTY Cuda
Re: Right Place?
« Reply #516 on: January 28, 2007 - 07:17:24 AM »
I try & do it right, but I do a lot of "Joe homeowner" stuff if you know what I mean, the capilers & such are just bombed with 2 coats of minwax polyurathane semi gloss clear, all non contact rotors & drums I did in por15 semi gloss black, I have to coat everything being the car is outside!
On the lines I thought I ordered the right ones from year one, the longer one was just some tweakin, the short one in a loop I had to remove the loop & basicily reroute it was facing away from the proportioning valve its now has no loop but does reach & route ok, again,not "correct" ! Rich
« Last Edit: February 01, 2007 - 06:43:18 PM by RUSTY Cuda »
Offline 74chall
  • Mopar or No Car
Re: Right Place?
« Reply #517 on: January 28, 2007 - 07:49:49 AM »
So rich, were the lines for a power car??  :popcorn:
Offline RUSTY Cuda
Re: Right Place?
« Reply #518 on: January 28, 2007 - 08:02:09 AM »
Now your gonna make me pull out the bill & the book & check the #'s,   :naughty:
 I've messed up a few times, got 2 - 26 inch rad shrouds now, I need a 22"  :clueless:  one new & one I got off ebay, saw 73 & jumped on it, anybody got a 22 & wanna trade!
Offline RUSTY Cuda
Re: Right Place?
« Reply #519 on: January 28, 2007 - 08:16:30 AM »
Book says manual disc brakes,72 & 73 , part # HF49 page 293 in year one catalog or you can go on line & search by part # .
Fittings were correct but not bent right! Rich.
Offline Plum6Pak
  • Plum6Pak
Re: Right Place?
« Reply #520 on: February 10, 2007 - 08:21:40 AM »
Hey Rich, haven't checked in here for a while, looking good! Nice job on all those parts, can't believe how you've transformed them from the way they looked before.  :2thumbs:
Offline RUSTY Cuda
Re: Right Place?
« Reply #521 on: March 24, 2007 - 01:31:47 PM »
Wow it's been a while, all I got done is a few plastic splash shields cleaned up in the last month or so, got my 9.99 ebay valve covers the other day, a little time to play today, so I started up both cars & let em run a while & then got to work on the valve cover cleanup, almost forgot the before shot!
« Last Edit: April 21, 2007 - 05:10:22 PM by RUSTY Cuda »
Offline RUSTY Cuda
Re: Right Place?
« Reply #522 on: March 24, 2007 - 01:36:23 PM »
Got the outside of the first done, back side is all rust, so I'm suckin rust dust again! >:(  but after a little straightining of the edges & a wee bit a paint they should look ok. Snows almost gone here so soon I can get back outside , panel alignment is high on the list so I can finish the hood & touch up my chips, maybe be done with paint this year  :dunno:  I'm hoping! Rich.
Offline RUSTY Cuda
Re: Right Place?
« Reply #523 on: April 21, 2007 - 05:06:55 PM »
Finally got in a few hours on the car today,ran both cars for about 20 mins to get the fluids flowing, sanded on a few boby parts, still need a free sat to get some help to align the body panels so i can finish touch ups & paint. doesn't look good for a week of two.
So i messed with splicing in my new newtral safty switch & repair harness(old ones just would NOT stay on!  :swear: )
So I won't dare pull this one off the new switch, it's tight & it's staying on there.
messed with my old & replacement harness'(s) (how do ya make that plural :clueless: ) & found if I removed the a/c wires(which I dont need ) I can remove the harness, make the splice & install the switch(spinning the wires) & then just re plug the harness in, my old one had a plug half way up so I used that one.
Wow, thats a lotta wind for a little job,anyway now all i gotta do is crawl under there & maybe i can finally start the car from the key!  :naughty: Rich.
have no heat gun so I had to torch the shrink tube, barley enough heat  ;)  but got it done! :grinno: Rich.
« Last Edit: April 21, 2007 - 05:09:05 PM by RUSTY Cuda »
Offline Street_Challenged73
Re: Right Place?
« Reply #524 on: April 22, 2007 - 02:31:12 PM »
The 'Cuda is looking very nice! :grinyes:  It's been cool watching this car come together. :thumbsup:
