Author Topic: Right Place?  (Read 140930 times)
Offline RUSTY Cuda
  • One big step foward!
Re: Right Place?
« Reply #660 on: February 24, 2008 - 09:19:17 AM »
Thats the kit I got, here's the link BB..........
http://cgi.ebay.com/ebaymotors/Cuda-Challenger-Door-Mirror-Nuts-Screws-Install-Kit_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el1262QQcategoryZ10076QQihZ008QQitemZ180198342280QQtcZphoto
Too much hassel trying to get the nut on the back with all the hardware in, there is an actual tool for those nuts, grainger sells the kit I think there called "nutserts"(tool with assortment of nuts for about 70 bucks) but I have a friend with it, just not close by so I'll wait on it, it's like a rivit gun, put threaded piece in, attach the tool & squeeze!
Got snowed on here a little anyway, will take a while before i'm outside again  ::) Rich
Offline RUSTY Cuda
Re: Right Place?
« Reply #661 on: February 24, 2008 - 09:22:31 AM »
Yea Glen, more than my fair share of "do-overs" , too bad there not free like mulligans! :naughty:
Have not checked on the tranny leak since I put the yolk in, hopin I don't need the seal, Thanks again! Rich.
« Last Edit: February 24, 2008 - 09:24:07 AM by RUSTY Cuda »
Offline RUSTY Cuda
Re: Right Place?
« Reply #662 on: April 13, 2008 - 03:09:46 PM »
Well not a lot of car time latley, lifes little monkey wrenches have ben flyingh my way.
Went out for a while today & got more electrical stuff workin. 340 bros, I used one of those fuses,thanks for the overkill on the fuse supply! that got most workin, scrapped up some grounds & got the top dash lights on, heater control & rear plate light still not on, but really didn't dig too deep on those.
but now (after the plate light) I'll be night legal!
Got a front bumper filler, clean,paint that & I can drill out the grille for mounting(must be a 72 grille, no holes for the filler screws.) Borrowed a nut sert tool & got the inset tightened up, just need to drill out the other door & I can mount the mirrors
So thats about it for car stuff for now, see yas around! Rich.
__________________
Offline RUSTY Cuda
Re: Right Place?
« Reply #663 on: April 19, 2008 - 05:34:47 PM »
K , got a few hours in today. Mounted the drivers side mirror, ended up using the old one, I have a slightly better one, but no gasket, so for now at least I have one on!
Offline RUSTY Cuda
Re: Right Place?
« Reply #664 on: April 19, 2008 - 05:40:06 PM »
Drilled out the pass door for the nutserts & installed those(will post the tool over in tech for those interested) had another gasketless mirror so I put some foam under it till I get the gasket set. I messed quite a while trying to get an aftermarket ariel in, could not get it to look right straight so I used the angle setup, maybe i can locate a decent original before too long?
Added an extta ground wire to the rear plate light & got that workin, so just the heater switch light is out now!
Offline RUSTY Cuda
Re: Right Place?
« Reply #665 on: April 19, 2008 - 05:44:35 PM »
mounted my tach, got 4 wires, red /blk/white & green. gussing the red is light? blk is  ground?(has a circle spade on it) I know 1 goes to the distributor (no sure which side) & the other? any help appreciated, again I'll repost in tech. thanks,Rich.
Offline wally426ci
    • maryland mopars
Re: Right Place?
« Reply #666 on: April 20, 2008 - 08:09:31 AM »
looking good!!
post something in the wanted section, we may be able to help out with parts!  :popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline RUSTY Cuda
Re: Right Place?
« Reply #667 on: April 20, 2008 - 09:30:31 AM »
I haven't searched ebay yet for the gaskets, if I can't find em I'll post up, the antenna is no big deal, not a "correct" car anyway, if it stays in(underside barley grabs in the hole) I'll leave it on. Thanks,Rich.
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
Re: Right Place?
« Reply #668 on: April 20, 2008 - 12:58:50 PM »
I have a couple old Mopar antennas. I'll check them to see if any look lke my Chally's. I'll let you know. By the way. looking good.  :2thumbs:
Offline bb71challenger
Re: Right Place?
« Reply #669 on: April 20, 2008 - 05:33:56 PM »
Great job on the car Rich! You will be cruising in style with that bad boy  :burnout: When I read your thread I think about Moparnuts all the time. I think about sending the magnum exhaust manifolds packed in spray foam lol. What a maroon for not even putting them in a bag  :smilielol: Anyway, glad to see you are plugging away at it  :2thumbs:
*Brett*
Offline RUSTY Cuda
Re: Right Place?
« Reply #670 on: April 20, 2008 - 06:45:35 PM »
I was lookin for a "car wash "antenna like my 74 had, saw this on ebay & thought it was the right one, it's got that tilt look like the old school 57 cheby guys had (No insult intended I like them old chebbies myself)
But thanks for lookin for me DNCH!
BB, good thing you weren't  shipping a puppy!  :eek4: Rich.
Re: Right Place?
« Reply #671 on: April 20, 2008 - 07:02:01 PM »
No problem  :cheers:
Re: Right Place?
« Reply #672 on: April 20, 2008 - 07:06:19 PM »
LOL I would at least put a bag over its head to ensure at least a small bubble of good air  :rofl:
Did the windage tray turn out to be of any use?
*Brett*
Offline RUSTY Cuda
Re: Right Place?
« Reply #673 on: April 20, 2008 - 11:03:29 PM »
never got the hardware so I'm saving it for the 74
Re: Right Place?
« Reply #674 on: April 20, 2008 - 11:10:54 PM »
Yeah I bet it is like I figured, probably cheaper in the long run just to get a windage tray kit as opposed to getting just the main bolts and windage tray bolts seperate  :(  The car sure is looking good though. I am really dreading taking off my hvac unit to rebuild it. How much of a pain was it? Yours turned out nice.
*Brett*
