Author Topic: Right Place?  (Read 141038 times)
Offline RUSTY Cuda
  • One big step foward!
Re: Right Place?
« Reply #765 on: August 18, 2010 - 08:02:45 PM »
Took it to my mechanic for a safty/ blunder inspection(remember this is my first resto) &
now for the long asssed report on the car, we got some good news & some bad, the tranny mount is shot, thats both, good because thats the major klunk, the bad is now I have to change it!
Alignment had to be fudged a little, tie rods at max(one all the way in the other all the way out) still left us off a bit, adjusted the camber or maybe the toe to offset that, so it won't pull to the right(if I'm getting what he did correctly, but that brought all the #s on the mac to within point five.
The rear is off .75 on one side & .45 on the other, so they think it's not only in crooked but also bent a tad, they say nothin to worry about.
Got a power steering leak at the shaft, small oil leak at the rear, gonna tweek the oil pan bolts & see if that does it, it's that or the rear main seal?
Gotta adjust the kick down when we do the tune up sunday, was shifting in auto to soon.
Now for one of my better blunders, I had no nuts on the back of the strut rods, amazing they didn't fall out, must have removed them when I dismanteled, I couldn't get the rods out so I cleaned up the control arms & rods as a unit, reinstalled & never noticed the nuts were missing!
most other stuff seems ok so far, the mopar guy over there still hears a little rear end noise,sunday I'll have greg take a listen & see if we should dig further?
Considering what I did to this poor car I'm pretty happy with these results, now I didn't get the bill yet so that may change my good humor a tad! Rich.
Offline RUSTY Cuda
Re: Right Place?
« Reply #766 on: August 22, 2010 - 07:50:38 PM »
Wow, this is gonna take some time, seems I have a few problems, We spent the entire day on the rear end, did have bad bearings, seems it got some moisture in it during storage, we pulled the center section, cleaned that & the inside of the housing,center section ok, stole the axels out of the 74 & slid em in, I just have to fill the lube & set the axels & the rear should be ready to go.
The clunk is comming on the early tranny shifts, adjusted the kick down but there's still a little play in the rod & only opens 3/4 to 7/8 of it's through(short of full open at the tranny) but it still shouldn't shift that early.
No auto trans gurus I know so I'll take it to a shop & get an estimate, if not major I'll just let em do it.
with the rain & hunt for a parts store on sunday thats all we got done,never got to the fine tuning on the engine, or the other little things on my to do list but considering the day we had I'm happy to at least have the rear fixed & know where the clunk was comming from! Rich.
Offline RUSTY Cuda
Re: Right Place?
« Reply #767 on: August 23, 2010 - 07:50:11 PM »
Posted some questions in the tranny section, so just an update here, finally headed in the right direction, stole the carb of the 74 & got a little better results with that linkage, still shifting eary but not as bad, no rear end noises on the test drive, so I hope thats good to go.
Still gotta fine tune the motor, but no real bad bogdown with this carb.
If I can't get her tweeked with this linkage I may ravage the 74 a tad more & use the kickdown from it?
At least today was all foward progress, that might be a first for me! :naughty: Rich.
Offline RUSTY Cuda
Re: Right Place?
« Reply #768 on: August 24, 2010 - 02:22:03 PM »
Offline RUSTY Cuda
Re: Right Place?
« Reply #769 on: August 28, 2010 - 09:13:17 PM »
whew, what a long day,leave it to us backyard mechanics to take a small project & turn it into an all day affair!  :lol:
Called the parts house around nine am & the steering box was in, picked up charger man & headed out, got back before ten, he had some errands to run so I started setting up the tools, dragged out the engine hoist, floor jack, jack stands & about all the car related tools I own!
Started buy pulling the drivers side front tire & the 2 plastic splash shields,battery & tray, got the box loose & need about 2" more between the headers & the inner fender, so we loosened up the motor mounts (ditching his solid mounts for reg)& started lifting the motor, crap, bout 3/4 of an inch short with it straight up in the front.Pulled the high press hose from the pump & cleaned up that mess. Put on the pass side mount, lowered her down & started all bolts over there. put a block under the drivers side & lowered the hoist so we could remove the pass side chain. set it up on the drivers side only, hoisted her up again & after it hit the limit we were a cats hair from clearing, one guy shoving the motor the other pulling the box out she came.
by now it's already like 3 pm . Set the new box in, got the bolts in & proceded to wonder how we would ever get the crap lined up again, motor might be sitting a tad higher on the new mounts cause the tie rod is now resting on the headers & wont clear the bolt on the idler, after some more head scratching & a little BBQ prepared by the gracious wife we loosened the boxes mounting bolts & lifted it up & slid the bar under & dropped the bolt in, C-man retightened all the stuff under there & I put the hoses back ,started to tighte up the motor mounts, finished those off & removed the hoist, filled the pump, cranked her over some, refilled, never really blead it, but she's full (rechecked after a test drive, but more on the later) what, there's more you ask, we this is Rusty, soooo........
C-man took off around 6, I cleaned up back there, bout an hour just for that, took a quick shower to reawaken my spirits & took her out for a test drive.
Had the perfect place too, they just repaved my street, smooth as a babys ass.
Slow ride straight down, around a block to turn around & stopped back by my house to check the fluid, good to go. Took her out on that longer 45mph road & she tracks straight, but my steering wheel is a 1/16th to 1/8th off, not a lot of play either, so that was the box.
tranny still clunks out the auto upshifts real early, 5mph 1 to 2 & 8 to 12mph 2 to 3 , no noise on a manuel shift with a little throttle.
With a little more throttle it was maybe 12 & 20 mph on the 2 shifts.(still clunking)
Had a tad of fun, got my first thumbs up, from a guy in a cedes no less, just as I was turning onto that bigger road, well I was in low, took off with a little more throttle & left him a nice CHIRP going into second
Speedo cable was not bad today, now I'm wondering if I need to change it, maybe I'll give it another shot of oil & see.
Oh yea had to grind the nut off the new motor mount, we went through hell not to pull those headers for the steering box, I wasn't about to pull em for a bolt. so I used 2 bolts like the solid mounts had.
Shes a tad quieter under neath, much less vibration , still waiting for the rear seal goop, that should be in mon or tues, another (though frustrating at times) day of foward progress, this could be a record, 2 in a row, I'm on a roll! Rich.
« Last Edit: August 28, 2010 - 09:18:14 PM by RUSTY Cuda »
Offline DAYLEY/CHALLENGER
Re: Right Place?
« Reply #770 on: August 28, 2010 - 10:14:09 PM »
All I  can say is........... :2thumbs: :2thumbs:
Dave or David
Re: Right Place?
« Reply #771 on: August 28, 2010 - 10:53:39 PM »
You had a big day it sounds like. Glad it worked out.
Offline RUSTY Cuda
Re: Right Place?
« Reply #772 on: September 01, 2010 - 07:06:32 PM »
More tweekin today, pulled the fuel sending unit, bent the crap outta the float & put 20 bucks worth in, moved up to little over half, sloshed her around the hood, no leaks & went back & filled it up, almost makes it to the full line , sloshed it around town some more & looks like no leaks. Now I gotta find out where empty is!  :naughty:
After my road tests I checked the brake lights, yep there on again, crawl under there & the bar is now bent! Rebent the bar & adjusted again, we will see what tomorrow brings!  :dunno:
Put on the pinion snubber , checked the front end area for leaks, gave the valve cover bolts a turn & all is dry cept the rear seal area, did not get to napa today, hoping the goop will be there tomorrow.
Still waiting on those results to see if I get the trans checked out next.
Gonna pull the kick down outta the 74 tomorrow & get that cleaned up & ready for the switch.
Might get lucky on the steering wheel being off I think I have to go opposet the all the way in & out tie rods? could I be that lucky!  ;) Rich.
Offline RUSTY Cuda
Re: Right Place?
« Reply #773 on: September 19, 2010 - 09:41:05 AM »
Got some more problems solved, ravaged the 74 & put in the kickdown linkage, adjustment is at the trans on this one(PITA) but I think I've got it adjusted correctly.
1st highway drive, went on easy took her up to 60-65 all seemed good, no major vibrations , on the return trip I entered slow & waited for traffic & from about 20mph I nailed it, she downshifted & did not shift till 6200(aftermarket tach) was doing around 60, so the governors either bad or has been played with or changed. took her up to 75 or so & all seemed fine. exiting the hiway she just died, only way to keep it running was raise idle to 1500, after posting prob, seemed most thought vac leak. to be continued!
pic of new kickdown!
Offline RUSTY Cuda
Re: Right Place?
« Reply #774 on: September 19, 2010 - 09:51:03 AM »
Did a manifold gasket set & carb spacer set, but one of the carb studs stripped out, was going to drill it out & tap in the next size when I noticed all the parts had a second hole inboard, fender stud fit perfect, so I hope that will be ok. think I got the vac leaks solved, now she runs a little rougher on idle & when I nail it it stalls but it goes up easy fine, think I have to start from scratch & retime & tune, tryig to get a more knowledgable friend over to help set that all up.
Took a short ride this am & it runs ok, will go for a longer drive later to get it hot & be sure the vac prob is fixed(I let it get to 230 in the yard & then sprayed carb cleaner all around the manifold & carb & got no reaction!)
trans still shift with a clunk real early, but nice solid shifts under load???
new stud location.
Re: Right Place?
« Reply #775 on: September 19, 2010 - 09:54:36 AM »
Good News/ Bad News....keep on thrashing, the shift seems a little late based on what mine did, about 5500 WOT shifts, a little adjustment on the kick-down may bring it down if that's what you want. How does it shift during normal driving?
Offline RUSTY Cuda
Re: Right Place?
« Reply #776 on: September 19, 2010 - 10:02:56 AM »
Really early with no load, in drive well before 20, with a little throttle  around 12 & 20 on the upshifts, but has a clunk to go with it, ujoints are good!
Re: Right Place?
« Reply #777 on: September 19, 2010 - 10:16:03 AM »
Late at WOT, Early otherwise don't sound good to me.....tactransman time.
Offline RUSTY Cuda
Re: Right Place?
« Reply #778 on: September 19, 2010 - 01:58:19 PM »
Drove around the area for about 1/2 hour without incident ,never really got over 200ish , but did not try to stall at stop lights & such, I'm hoping the vac leak problem is solved!
when I get it out on the highway again I'll take notes on how the tranny is shifting under different conditions & then post up for advice. Thanks for the help,Rich.
oh yea filled the tank & calculate gas milage at 5.3 mpg,last time it was around 7 with a little hiway drivin(very little) anyway this has to improve with tuning otherwise my range will be from one gas station to the next!  :faint: Rich.
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
Re: Right Place?
« Reply #779 on: September 21, 2010 - 08:46:04 PM »
WOW!  You have come quite a way since the last time I read up!  Way to go!
