Author Topic: 318 /340 - Converter / stallspeed..???  (Read 816 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: January 04, 2010 - 12:04:05 PM »
Will there be a large difference in stallspeed on a 318 / 904 and a 340 / 727...???
I got a 340, but with the 904 tranny from the original 318 engine,  - I can't smoke tires, need a lot of rpm's on the 340 before it performes, but the stall is so low the car gets going like a ferry..  :bricks1:
Offline tactransman
Re: 318 /340 - Converter / stallspeed..???
« Reply #1 on: January 04, 2010 - 12:26:10 PM »
The 318 converter is a lower stall than the 340 wants for sure. You need to go aftermarket on the converter,especially if the 340 is "pumped up" more than a stock one.
Terry-tactransman
Union, Mo.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #2 on: January 04, 2010 - 12:38:10 PM »
The 340 is a little "pumped up"  headders and - ???  not sure about the cam..
What stall will a stock 340 have.. ???
Offline tactransman
« Reply #3 on: January 04, 2010 - 12:54:56 PM »
Around 2200,your 318 one is probably around 1800.
Terry-tactransman
Union, Mo.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #4 on: January 04, 2010 - 12:59:25 PM »
Do I invest in a stall conv. for the 904, - or do I do better getting a 727 ..  ???
Offline tactransman
« Reply #5 on: January 04, 2010 - 01:40:13 PM »
Do you have a 727? If so,then yes,go with the 727 and a stall.Make sure your 340 is tuned to it's best also because a 340 with a 318 converter should be pretty peppy yet. Is the engine idle real "lopey/rumpity"?
Terry-tactransman
Union, Mo.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #6 on: January 04, 2010 - 02:28:00 PM »
I have been thinking of getting a 727, - for a couple of years, - but has waited, cours my mind is on a bigblock - kind of a bigblock guy..   :burnout:
The 340 is a little jumpy in idlle, but not a lot, - almost stock I think, exept for the headders and doublepumper carb..
Offline tactransman
« Reply #7 on: January 04, 2010 - 02:58:53 PM »
I would say that the 340 needs some tuning and then it might run more to your liking with the 904/converter you have. I am assuming that it is a '71 and earlier 340 (Steel crank)
Terry-tactransman
Union, Mo.
