Author Topic: back window clip  (Read 836 times)
Offline coupman35
  • It going to be FUN
back window clip
« on: January 04, 2010 - 08:47:41 PM »
Am installing my back window am putting the moldding clip in does any no if the two center clip have to be screw in  , all of the other one have a little pin that holds it in place .this is  for my 73 challenger
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
wagesofsin
Re: back window clip
« Reply #1 on: January 04, 2010 - 09:01:11 PM »
all mine had pins, but i cant say its the only way.
are you missing the clips?
Offline coupman35
« Reply #2 on: January 04, 2010 - 09:05:23 PM »
Yeo the kit came whit 20 clips an in the middle it look like there goes a clip there is a hole on each side so am asuming there must be a clip
wagesofsin
« Reply #3 on: January 04, 2010 - 09:24:36 PM »
your saying there is a hole on each side of the center where a clip should be?.
then i would screw the clip on. if the pin is gone, and you have a hole thats all i can come up with, can you get a pic?
would make it soooo much easier to actually see.
Offline coupman35
« Reply #4 on: January 04, 2010 - 10:16:14 PM »
you can see the hole there is one on each side same place
« Reply #5 on: January 04, 2010 - 11:55:11 PM »
I posted this earlier but didn't go through I guess :clueless: My '73 had two clips screwed on about 1/2 to 2/3 the way up the side near where the roof and 1/4 panel meet. I had assumed a previous owner did that to replace broken pins, but maybe not.
wagesofsin
« Reply #6 on: January 05, 2010 - 07:28:01 AM »
sounds right.
Offline coupman35
« Reply #7 on: January 05, 2010 - 02:41:01 PM »
this what i found out look like the back has 2 clip that are srew in the front also has 2 that are srew in the clip are not the same as the other one if you look at the pic yousee the lower part of the one that srew and the other one goes on the pin.
Offline 426HEMI
« Reply #8 on: January 05, 2010 - 02:51:40 PM »
Some were put on by screws for sure.  Sometimes the studs came out and it was easier to fix with a screw. Use screws that are short headed on those  :2cents:  Seen this done many of times
1970 M46 Barracuda
1998 Dodge Darango
Gordon
