Author Topic: converter difference  (Read 3123 times)
Offline mojavered
  • Someday!
« on: January 05, 2010 - 04:20:06 PM »
Looking at a torque converter, is there an easy way to tell that it is for a big block or small block?  Was there a difference in the Hemi or 440 six pack converters than the ones uses on a 440 or 383?  Thanks!
Jason
Offline oldkimmer
Re: converter difference
« Reply #1 on: January 06, 2010 - 12:45:24 AM »
............they all fit big or small block 727s,...............all have different stall speeds and stall differently behind different engine sizes.........66 up is new style..................kim............ :canada:
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline Moparinho
  • "Too many Ferrari and Lambo around me..."
« Reply #2 on: January 06, 2010 - 05:13:35 AM »
the more importat criteria during a torque converter selection is the stall speed.  If I'm not wrong, the original stock converter had about 1.000rpm stall while if you plan to have a more powerfull engine (>500hp) and a lot of fun spinning your wheels, you can go up to 3.000rpm as stall speed.
Paolo (Italy):
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383  (coming soon...)
'65 Shelby Cobra 427 Replica
Offline tactransman
« Reply #3 on: January 06, 2010 - 08:05:13 AM »
The more important difference is balance weights on the converter for different engines.
Terry-tactransman
Union, Mo.
Offline mojavered
  • Someday!
« Reply #4 on: January 06, 2010 - 12:49:47 PM »
I had my tranny rebuilt and a converter traded in old converter for new one.  Some guy that came by my house said that the converter I had was for a small block.  I could not go to the man that rebuilt my trans because he passed away.  So, I guess I just need to press my luck and go on town to a couple shops and see what they can tell me about it?  See if it is set up for a big block?  I am just wanting to run stock stall speed converter, but want to make sure that it is set up for my engine.  Any suggestions?  Anything in particular that people are going to want to know about the engine?  Thanks!
Jason
Offline tactransman
« Reply #5 on: January 06, 2010 - 12:54:03 PM »
Post a pic of the front (threaded pads side) of the converter and I can tell you what you got.
Terry-tactransman
Union, Mo.
Offline mojavered
  • Someday!
« Reply #6 on: January 07, 2010 - 01:13:50 PM »
Thank you sir!  Here is a pic of the front and back.
Jason
Offline tactransman
« Reply #7 on: January 07, 2010 - 01:28:08 PM »
That converter is a small bowl (bolt pattern),will fit 318,440 STEEL crank,340 STEEL crank and 383.
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #8 on: January 07, 2010 - 01:29:42 PM »
Oh.... and the "H" on the part # means it is a high factory stall (around 1800-1900 RPM)
Terry-tactransman
Union, Mo.
Offline mojavered
  • Someday!
« Reply #9 on: January 07, 2010 - 04:51:07 PM »
So, if I have an after market forged crank, I should be fine with that converter?  Thanks!
Jason
Offline tactransman
« Reply #10 on: January 07, 2010 - 04:55:39 PM »
Yes,it should be internally balanced.
Terry-tactransman
Union, Mo.
« Reply #11 on: January 07, 2010 - 04:57:23 PM »
I believe so, as long as your cam isnt to big :2thumbs:.  Personally, I'd want a bit bigger stall, maybe a 2400/2600, but the lower the stall the less slipage and better fuel economy
Offline mojavered
  • Someday!
« Reply #12 on: January 07, 2010 - 06:46:47 PM »
Thanks!  Hopefully it was!
It is predominantly a street car, pretty small cam, only .528 or so.  I think that the stall should be perfect.  When I upgrade the cam, then I will start looking at more stall.
Jason
« Reply #13 on: January 07, 2010 - 08:29:06 PM »
 A 509 cam wont work with it, nor do I believe a 528 would suffice.
Offline tactransman
« Reply #14 on: January 07, 2010 - 08:47:36 PM »
It will "work" but your engine will not perform the way it could. You should have about a 3000 stall.
Terry-tactransman
Union, Mo.
