Author Topic: converter difference  (Read 3121 times)
Offline mojavered
  • Someday!
Re: converter difference
« Reply #15 on: January 07, 2010 - 09:16:43 PM »
When you get up into that stall range, don't you start having a lot more problems with heat, etc..  What kind of performance problems would I have or be limited to by using this converter?
What kind of stall did a 440-6 or the Hemi use stock?
Jason
« Reply #16 on: January 08, 2010 - 07:24:24 AM »
stock was like 24 to 26 for 6pk and 26 to 28 hemi, with a lot smaller cam than yours.  You will most likely have idle problems when idleing in gear and a real turtle when you take off. 3k stall will not create any extreme over heating problems, you can also run a bigger capacity pan and a cooler. Both easy to install and not hard on the wallet.
Offline tactransman
« Reply #17 on: January 08, 2010 - 09:15:36 AM »
A 3000 stall is VERY streetable. What engine do you have and what are the specs on it?
Terry-tactransman
Union, Mo.
Offline mojavered
  • Someday!
« Reply #18 on: January 08, 2010 - 11:59:02 AM »
It is a 70 440 block with a 4.375" stroke, 4.35" bore, 10.13 CR, hydraulic cam with duration 278/235 with .504" lift int and exh.  (small cam. I was thinking that it was a .528 lift, sorry for the confusion).  Indy Cylinder Heads, flowing 270.3 intake and 203.6 on exhaust @ .500 lift (287/219.8 @ .600).  Edelbrock Performer RPM intake.  Crank is forged.
71 Challenger, 727, 8 3/4, 3.55's, 275/60/15.  Power brakes and 99% street car.
This entire torque converter ordeal has got me very confused.  Everyone has different ideas of what should work and what works.  Is there a torque converter book for dummies?   It wold probably confuse me more anyway.   Thanks for the help.  If there is anymore info you need that would help, let me know.
« Last Edit: January 08, 2010 - 01:11:21 PM by mojavered »
Jason
Offline Oldschool
  • Member Since 9-05-06
« Reply #19 on: January 08, 2010 - 12:15:10 PM »
I am running a 4:10 gear in a 3500# car. I am running a small solid roller cam, 30" tall tires, and 2 carbs.  I have a Continental 3800 stall converter. Very streetable with no overheating issues. It will flash at around 4400-4500 rpm for drag racing. Not a great choice for racing, but it works well on the street and fine at the track. Never gonna get great 60' times with it. I have never been able to tell I even have a higher than stock converter in it. It drives as normal as my old stock Hemi cars did.     :2cents:
Ken  --  In Georgia
Offline tactransman
« Reply #20 on: January 08, 2010 - 12:21:42 PM »
OK....... That 440 should have some low end torque,I would go with a TCI Breakaway converter.
http://www.summitracing.com/parts/TCI-141200/
Terry-tactransman
Union, Mo.
Offline tactransman
« Last Edit: January 08, 2010 - 12:25:08 PM by tactransman »
Terry-tactransman
Union, Mo.
Offline shadango
« Reply #22 on: January 08, 2010 - 12:52:07 PM »
 :iagree:  Terry had suggested this convertor for my car ...... cammed 318 with j heads, headers, mainifold and carb.....and I really love it so far!  I punch the gas and it flashes up and takes off now....with the stock one it was a dog.
And I still have my 2.76 gears.
Offline mojavered
  • Someday!
« Reply #23 on: January 08, 2010 - 01:15:02 PM »
Should have plenty of low end torque!!!
OK, With that converter, it appears that I am not going to have to worry about heat too much??  When is a cooler recommended?
Al, thanks for the info on the stock stall speeds.  I never knew they were that high.
I am going to have to read up on those links you posted, thanks for that.
I think I will take this converter down to the shop it came from and see what they can do to come up with a converter that matches the specs mentioned with the breakaway converter or get me that one.
Thanks to all for your input.
Jason
Offline tactransman
« Reply #24 on: January 08, 2010 - 01:18:07 PM »
 :2thumbs:
Terry-tactransman
Union, Mo.
Offline mojavered
  • Someday!
« Reply #25 on: January 08, 2010 - 05:01:52 PM »
When I went down to the shop, they looked at everything and said that I really need to go with a 10" converter.  They said with the numbers I am showing, I am likely to damage a 11" pretty easily.  What are your thoughts?  They said the converter that I have is a 2000 stall and can be modified to make it a 26-2800, but it probably would not hold up very long.
Jason
Offline tactransman
« Reply #26 on: January 08, 2010 - 05:13:43 PM »
I would go with the breakaway. TCI's are made stronger on the inside than a stock converter.
Terry-tactransman
Union, Mo.
