What is the proper procedure for trunk pan & qtr. replacement?
Author Topic: What is the proper procedure for trunk pan & qtr. replacement?  (Read 11554 times)
Offline RUSTY Cuda
  • One big step foward!
Re: What is the proper procedure for trunk pan & qtr. replacement?
« Reply #15 on: September 30, 2004 - 10:01:58 PM »
Looks like you got some work too, I think it's a good idea to seal em while their open, easy enough now , just slop some por15 or eastwood stuff in there & no future worries!
here's a few shots of the job
one side being prepared for weldin, por15'd & weld spots cleaned.
[attachment deleted by admin]
Offline RUSTY Cuda
« Reply #16 on: September 30, 2004 - 10:04:04 PM »
Pans welded in, went a little wild here, warped the pan doing it, (my first time) but she's solid!
did a little better on the drivers side! ::)
« Last Edit: September 30, 2004 - 10:19:54 PM by RUSTY Cuda »
Offline RUSTY Cuda
« Reply #17 on: September 30, 2004 - 10:05:56 PM »
here's one of those extensions being fitted up for weldin, a lot of bending & rebending on this!
Offline RUSTY Cuda
« Reply #18 on: September 30, 2004 - 10:18:32 PM »
Had to fab up the bottoms of my tail light mounts, lotsa fun on this car!
Offline RUSTY Cuda
« Reply #19 on: September 30, 2004 - 10:21:16 PM »
Just like new, errrr well almost! ;D
Offline Steve
  • I Love Welding!
« Reply #20 on: October 01, 2004 - 06:47:00 AM »
D@MN! I thought I was the only one crazy enough to put this much work into a '72!    :o :o
That's some super work!
Offline RUSTY Cuda
« Reply #21 on: October 01, 2004 - 07:26:30 PM »
Yep, I'm crazy, but what do you do after you laid down your money & the car is home, This is my first  resto, so it's good it's a clone, cause I've made a lot of mistakes along the way, but I had to learn & thats still going on, next car (is a bit dryer) & should come out better if I ever get this one done!  ???Rich.
Offline Steve
  • I Love Welding!
« Reply #22 on: October 02, 2004 - 07:15:04 AM »
RUSTY....my twin....seperated at birth...
Offline Steve
  • I Love Welding!
« Reply #23 on: October 02, 2004 - 07:36:18 AM »
OK. This is wierd. When I pulled my trunk pans out, the two middle braces (for the fuel tank) were NOT welded to the subframe of the car. I cut out the pans and the fuel tank braces came out with the pans! I didn't drill or cut on the braces at all. Were those braces welded to the sub-frame on your cars?
Plum6Pak
« Reply #24 on: October 02, 2004 - 08:11:14 AM »
 :o They are suppose to be Steve, mine were when I replaced my trunk floor, post some pictures when you get a chance. Hey RC, speaking of first time, this is my first complete also, it is costing an arm and a leg but I figure you couldn't go to any school and learn any better than tackeling the job yourself, learning from others here and other places as well. It's not a job, it's an adventure!! hehe, I am loving it though! Nice work by the way!  :D
Offline RUSTY Cuda
« Reply #25 on: October 03, 2004 - 07:30:23 PM »
Yep, most expensive school I ever went to!!
On those trunk braces mine were welded rear only, came up a couple a inches short in front, instead a tryin to do them off the car i made extensions outta scrap steel & welded em to the cross member in front! not sure if thats factory or not, but a lot easier to measure everything out!!!
Offline miketyler
    • www.miketyler.net
« Reply #26 on: October 04, 2004 - 06:32:39 AM »
Looks good Rusty - I did find a couple of shots of a 70 AAR model trunk. Owner claims this is original, maybe this could server as a visual blueprint? Ck it out:
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Steve
  • I Love Welding!
« Reply #27 on: October 04, 2004 - 08:08:13 AM »
On the trunk braces, mine weren't welded to the frame. I actually welded mine to the pan halves out of the car. there werre no spot welds on the main cross brace (the one near the rear shock mounts).
Offline RUSTY Cuda
« Reply #28 on: October 05, 2004 - 05:19:07 PM »
Hey steve, I added a couple of inches to them & did it myself, I had not removed the back 2 inches of the trunk pan so they were just hangin there, didn't have my "new" tail panel at that point so I didn't want to drill out the rears, seems to have worked out ok, the actual pan didn't rest on that cross member anyway! & I did all the weldin to the pan from the top.
Mike, may need that for the 74,thanks, 73 is going in as modified(just a tad) so I'm not going crazy with details, just want it to be clean! Rich.
