Author Topic: carter carb and intake matching  (Read 974 times)
Offline moparnut
    • My Photo's
« on: January 09, 2010 - 03:41:59 PM »
I cant remember which carb goes with which intake ect
Will a current production carter 4 barrel fit this intake?
thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline vinb
Re: carter carb and intake matching
« Reply #1 on: January 09, 2010 - 04:05:47 PM »
Almost what I have..(#8007 Weiand)...
That intake is about a inch higher than a stock T-Q manifold
Use a Carter Thermo-Quad with that manifold..
« Reply #2 on: January 09, 2010 - 08:52:23 PM »
those are meant for either carb square bore or spread bore , you just need to be very careful about making sure the gasket seals the carb to the intake properly
wagesofsin
« Reply #3 on: January 09, 2010 - 08:57:44 PM »
you can use whatever you want carb wise on that, just need an adapter plate.
i used this to mount a holley.
http://www.holley.com/17-6.asp
Offline vinb
« Reply #4 on: January 09, 2010 - 09:36:49 PM »
Yep, you can use that Holley adapter plate and flip it upside down and use a die grinder to get a nice match with the intake and square bore carb. Gaskets should not be a problem....
The Thermo-Quad has excellent throttle response with a dual plane manifold..
wagesofsin
« Reply #5 on: January 09, 2010 - 09:51:55 PM »
yep yep!
Offline moparnut
    • My Photo's
« Reply #6 on: January 10, 2010 - 10:53:28 AM »
thanks all
Offline moparnut
    • My Photo's
« Reply #7 on: January 10, 2010 - 11:21:45 AM »
the one i posted was the SUM-226040 summit dual plane. Is this a good manifold? I can buy this good used one for 90 bucks, dont really need it just collecting parts for a 340 build and future A body project.
thanks
