Author Topic: Kickdown Assembly - 71 Challenger 440/727  (Read 2236 times)
Offline t1971Chally
« on: January 09, 2010 - 07:45:11 PM »
Hello everyone,
Looking for the entire kickdown linkage system for a 1971 Dodge Challenger, 440 - 4 bbl, 727 Trans.  Please respond or email me at twiles1216@yahoo.com if you have one you are will to part with.
Thanks....
T1971Chally
Ted
1971 Dodge Challenger 440 Magnum
:cheers:
Re: Kickdown Assembly - 71 Challenger 440/727
« Reply #1 on: January 09, 2010 - 07:56:58 PM »
I had to go with the Lokar set up,couldn't find all the stock parts.
Offline t1971Chally
« Reply #2 on: January 09, 2010 - 08:29:12 PM »
Brads70,
You may just have the answer I am looking for!!!  I had to go with the Locar setup as well however the problem I am having is the bracket for the locar cable mounts on the back right corner bolt of the edlebrock carb and interferes with the throttle cable bracket(I ran into this when I changed carbs from Holley to Edlebrock).  How did you set yours up?  Do you have any pics you would be willing to share?
Thanks,
Twiles
Ted
:cheers:
« Reply #3 on: January 09, 2010 - 08:43:35 PM »
 I have a Holley on mine. But look on my old post here, it has some pictures of the eddy carb. :2thumbs:
http://www.cuda-challenger.com/cc/index.php?topic=55666.0
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: January 09, 2010 - 09:01:35 PM »
If you want all the factory linkage in one kit A and A trans makes the kit. little pricey but nice pieces, this is a complete kit with the trans lever as well.  350.00
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline t1971Chally
« Reply #5 on: January 09, 2010 - 09:08:05 PM »
Brads70,
Those pics definately helped!!!  It appears my problem is simply that I must remove the stock throttle cable bracket and use a bracket that mounts both cables.  Thanks again......I may finally back into busines with the car.....
t1971chally
Ted
:cheers:
« Reply #6 on: January 09, 2010 - 09:08:56 PM »
 :2thumbs: Got any pictures of it?
