Author Topic: couple of questions about headlight switch  (Read 577 times)
Offline IndyCuda
« on: January 09, 2010 - 08:14:48 PM »
My headlight switch works but you have to dig it out of the dash to pull it out as it goes flush with the dash when you push it in. Do I need a new switch or is there a spring I can change on it? I have never removed it before, how do you remove it?
Re: couple of questions about headlight switch
« Reply #1 on: January 09, 2010 - 08:19:12 PM »
it is screwed on the back of the switch panel , the screws could be just loose or fallen out
Offline IndyCuda
« Reply #2 on: January 09, 2010 - 08:50:56 PM »
Ok thanks
« Reply #3 on: January 09, 2010 - 09:06:59 PM »
Slotts on this site can repair the switch if needed
« Reply #4 on: January 10, 2010 - 07:50:41 AM »
OE switch does not push/pull....is a toggle switch that flips up/down.
