Author Topic: Won't Start  (Read 4673 times)
Offline the_engineers
Won't Start
« on: January 10, 2010 - 12:49:53 AM »
Took out the steering column to put in the FF box.  Put the column back in, started the car and drove for 30 minutes.  Brought the car home and parked it. Went to start the next day.  In the ACC positon, everything appears OK, but turn the key to START and nothing at the starter.
Put my starter button on the starter relay and the starter turns fine.  I will be digging back under the dash to check the connections, but shouldn't they be fine if I drove?
The shifter is cable-shifted, so I have not checked to verify the Park position, but the shifter "feels" fine.
Other options?  Ignition switch in column?  Neutral safety switch?
I'm on the road for the next week, but want to have ideas for when I return.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline ShelbyDogg
Re: Won't Start
« Reply #1 on: January 10, 2010 - 01:17:12 AM »
Yellow wire on the starter solenoid cames from the steering column start circuit. check it with a test light. If you have 12v in start position, then it is the other terminal on the relay that goes to the neutral start switch. You should have ground in it.
Re: Won't Start
« Reply #2 on: January 10, 2010 - 06:54:11 AM »
Possibly the terminal in the column plug slipped & needs to be pushed back in.
Re: Won't Start
« Reply #3 on: January 10, 2010 - 07:44:07 AM »
Normally I would first check the NSS, but seeing as the column was moved around, maybe disconnected, I would concentrate on the column connector. As Bullitt said, seated all the way on? If you disconnected/re connected, did any of the contacts get pushed out the back of the connector?
Offline 73Chally
Re: Won't Start
« Reply #4 on: January 10, 2010 - 09:35:58 AM »
Same thing happened to me a while ago.  Car ran fine one day, then nothing the next.  Turned out the plug at the bottom of the column must have vibrated just enough to lose the connection.
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Won't Start
« Reply #5 on: January 10, 2010 - 08:52:09 PM »
yes you should check were you had it disconnected ,,
72rtchallenger
what happens in the garage
stays in the garage
Re: Won't Start
« Reply #6 on: January 17, 2010 - 10:51:57 PM »
Alright, checked the connectors and re-connected.  Still nothing.
Time to check the starter relay next.
Brooks
1971 'Cuda 360
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
Re: Won't Start
« Reply #7 on: January 17, 2010 - 11:19:24 PM »
Did you try starting it in neutral ? Mine does that sometimes.
Re: Won't Start
« Reply #8 on: January 17, 2010 - 11:21:21 PM »
I'm not convinced that I'm in neutral...it's an aftermarket cable-driven shifter.
Brooks
1971 'Cuda 360
Re: Won't Start
« Reply #9 on: January 17, 2010 - 11:22:58 PM »
Try jumping it off the starter relay or maybe it's the ballist resister.  :dunno:
« Last Edit: January 17, 2010 - 11:32:31 PM by DoNotChallengeHer »
Offline ShelbyDogg
Re: Won't Start
« Reply #10 on: January 17, 2010 - 11:26:40 PM »
Try a test light on the yellow wire. Then follow it back all the way through the bulkhead connector, then to the ignition switch. Same yellow all the way back.
Re: Won't Start
« Reply #11 on: January 17, 2010 - 11:53:22 PM »
Along with previous suggestions...if they don't locate the problem, hold the key in the 'start' position and move the shifter and see if you get some action. Foot on the brake is a good idea.
