Author Topic: Shock crossmember  (Read 576 times)
Shock crossmember
« on: January 10, 2010 - 11:24:36 AM »
I was scraping undercoat and rust out from the back half of the car today and while the undercoating did it's job in most areas, it didn't do so well on the shock crossmember. Is it just attached to the two frame rails? Is it spot welded to the trunk floor at all?
I have the rear end, springs, gas tank and lines out of the car so it would be a good time to change it I guess. Would I have to brace anything before I cut it out?
 :1zhelp:
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: Shock crossmember
« Reply #1 on: January 10, 2010 - 12:05:53 PM »
if the trunk floor and or the under seat pan is cut out then I would just to be on the safe side. other wise the flooring welded to the rail should be sufficiant. either way it wont hurt
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline A R T
  • Looks like some one needs to be frisked....
    • Auto Rust Technicians/Safe-T-Cap
« Reply #2 on: January 11, 2010 - 10:34:29 AM »
The shock crossmember does not attach to any of the floor or trunk sheetmetal. If you have all the sheetmetal cut away, its a good time to replace it. Its a good idea to tack weld a couple of lateral supports to keep things aligned before you remove the existing one, it will help you when its time to install the new crossmember.
 :cheers:
Nothing to see here folks, Its just a Bluesmobile.
