I am not going for a whole kit anywhere because it seems the kits always include stabilzer bars and links....I dont need those......why pay for stuff I dont need.
Rock lists tww part numbers for Moog upper control arm bushings:
K408 which is the standard ones, and the picture shows 4 pieces
and
K7103 which is listed as "offset", and the picture shows two pieces. T
The picture appears to look very much the same as the Raybestos/AC Delco "eccentric" units which say they can be adjusted for extra positive camber....
So its an extra $27. But I figure that the upper control arm bushings would be a real pain to redo if I ended up needed them.
They also list a "problem solver upper balljoint....they are $20 more than the standard....
Standard
Problem sover
I cant tell the difference between the two there.....
Hmm, that will start to add up. The upper balljoint wouldnt be that big a deal to change out by itself, if I had to, right?
I was thinking of just getting the offset/eccentric moog upper control arm bushings and the standard balljoints and hope it s a good gamble.
What would you guys do?
