Author Topic: what is  (Read 1531 times)
sleepychallenger
what is
« on: January 12, 2010 - 05:19:58 PM »
the biggest tire i can fit on a 14 inch mag 500? i think 14x7
Re: what is
« Reply #1 on: January 12, 2010 - 05:48:27 PM »
something like a L60 I think
sleepychallenger
Re: what is
« Reply #2 on: January 12, 2010 - 06:05:59 PM »
What is...........
a L60?
Re: what is
« Reply #3 on: January 12, 2010 - 06:09:10 PM »
 :bigsmile:  antique...youngin   I dont know the conversion to the radial size.  Where you at bullit?
sleepychallenger
Re: what is
« Reply #4 on: January 12, 2010 - 06:14:37 PM »
i want to go to like a 235 but not sure i can...
Re: what is
« Reply #5 on: January 12, 2010 - 06:15:46 PM »
235x60 ?  i am thinking you can
Re: what is
« Reply #6 on: January 12, 2010 - 08:13:45 PM »
         Hea I Is Massa
My 14" Road Wheels are 5.5" wide ( I believe this is standard)... I have ran 235/60 on the rear with no problems but this is not ideal ... here is a pic of the crown compared to a 245 on a 9" rim
« Last Edit: January 12, 2010 - 08:21:35 PM by Bullitt- »
sleepychallenger
Re: what is
« Reply #7 on: January 12, 2010 - 08:23:40 PM »
so what is my widest best bet for my stock wheels?
Re: what is
« Reply #8 on: January 12, 2010 - 08:32:19 PM »
I have 235R60's on my 14x6.5 rallyes.
sleepychallenger
Re: what is
« Reply #9 on: January 12, 2010 - 08:34:28 PM »
why does it crown so much? i just want more meat in the rear.
Re: what is
« Reply #10 on: January 12, 2010 - 08:39:13 PM »
 I put several sizes in this calculator & 225 /70R14 is the largest that fits in specs of a 5.5 wheel
                   235 /60 looks much better,,,,,,might be time to consider a wheel change
http://www.1010tires.com/TireSizeCalculator.asp?action=submit
Re: what is
« Reply #11 on: January 12, 2010 - 08:39:45 PM »
narrow rim pulling in on the sides, the weight of the car does smash em down so you do get more traction.
sleepychallenger
Re: what is
« Reply #12 on: January 12, 2010 - 08:43:00 PM »
just trying to keep the factory wheels...how bad will the 235/60 be when on the car as far as crown goes? will the tire wear faster?
Offline Super Blue 72
    • Phil's Super Blue '72
Re: what is
« Reply #13 on: January 12, 2010 - 08:45:17 PM »
Due to the crown, the middle of the tread will wear faster than the edges will.
Ideally you want a rim the width of the tread.
Re: what is
« Reply #14 on: January 12, 2010 - 08:51:27 PM »
True but I don't think the tire wares out any faster just the outer edges won't wear much.
  When I got my car in '75 it had H-70s, about a 235, and this was what I observed.
