Author Topic: Cheap 1" torsion bars  (Read 9173 times)
Offline cudazappa
Re: Cheap 1" torsion bars
« Reply #45 on: February 15, 2010 - 11:30:44 AM »
big thing with the 1" t-bars is they have a 30 degree clock, no left or right. :bigsmile: i agree with 72bluNblu about the adjusting
2015 Dart GT - Daily Driver
« Reply #46 on: February 15, 2010 - 01:31:59 PM »
I tought I just got lucky with that? :roflsmiley:
Offline ajantics
    • Yeah......Im a drummer!
« Reply #47 on: February 15, 2010 - 01:37:42 PM »
 :smilielol: :smilielol: :roflsmiley: :rofl: :lol:
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Offline shadango
« Reply #48 on: February 15, 2010 - 11:50:41 PM »
So is that different from the stock .86 bars I had?
When I was disassembling my front end, I had used a floor jack under the control arm to lift it while removing the upper BJ nut.....
When I put everything together, I didnt have to use the floor jack to reassemble the upper BJ nut.....I just pushed the LCA all the way down, made sure the adjuster bolt was out as far as it could go, pushed the adjuster "arm:" down to meet the bolt, then slid the t bar into the socket....then move the LCA up by hand and connected the upper BJ nut......i never had to use the floor jack....??????
Did I screw something up in the "clocking" or is this correct?
« Reply #49 on: February 16, 2010 - 12:32:35 AM »
I never used a jack with the .96 bars I just installed , I had the lower control arm all the way down & was able to push the upper all the way down to the spindle
Offline shadango
« Reply #50 on: February 16, 2010 - 04:43:10 AM »
Thanks Chryco!    :2thumbs:
