Author Topic: Steering Pitman arm/linkage below oil pan  (Read 806 times)
Offline Marquis_Rex
  • Takes a Mopar to Catch a Mopar...
    • auto-scape
« on: January 17, 2010 - 03:46:31 PM »
I'm need to take the sump pan off my 440 RB engine in my Challenger. I've managed to take off all of the 1/2 inch bolts off around the sump, even the ones shrouded by the K frame. I've taken the cotter pins off and the castled nuts of the piman arm but am unable to seperate this lnkage off.
 :working:
i've used a fork type seperator and (and pretty much ruined the bushes) and hit it hard but it's still not seperated.
I've also tried a gear type puller- but still no success. :pullinghair:
Any one got any reccomendations? Any tools I should look into? Am I doing it wrong?
Pictures:
Cheers
1970 Dodge Challenger 440 R/T
1995 Porsche 911 turbo (993)
1982 BMW 323i "E21"
1985 BMW M635CSi "E24"
2003 Dodge Ram 1500 4x4
1971 Jaguar XJ6 series 1
2000 Jaguar "X308" XJR
1993 Mercedes 400E
1964 MCI MC-5 coach 'RV'
Re: Steering Pitman arm/linkage below oil pan
« Reply #1 on: January 17, 2010 - 04:14:15 PM »
If that 3 lever puller is holding good, get it real tight and wop the center link right at the puller with your hammer. You are doing all the right stuff. Bullitt has a set of front end pullers that work like a charm. He got them at advance for around 100 bucks.
Offline Marquis_Rex
    • auto-scape
« Reply #2 on: January 17, 2010 - 04:39:28 PM »
Thank you Moparal.
I may have to go out and buy some more/better tools.
The 2 legged puller photographed subsides and collapses when the pressure is exerted. May be I need one with a thicker stem.
I'll go to advance like you suggest. Thanks
1982 BMW 323i "E21"
1993 Mercedes 400E
Offline Changin Gears
« Reply #3 on: January 17, 2010 - 06:46:34 PM »
Sometimes you have to use a "mini" sledge hammer to make that pickle fork work.
Offline the_engineers
« Reply #4 on: January 17, 2010 - 07:09:20 PM »
I bought a tie-rod puller from O'Reilly for $12.  You can get a pitman puller just about anywhere for $15'ish.  Skip the rest of the kit.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #5 on: January 17, 2010 - 08:08:06 PM »
PB Blaster down each tapered shaft, let sit over night. Next day wack the center link ends, not the pitman or idler shafts, a few times with a medium sized ball pein with another hammer or dolly on the other side to break the hold. Try the puller.  Repeat until it lets go.
« Reply #6 on: January 17, 2010 - 08:30:31 PM »
You can pick up that front end kit at Advance Auto or Auto Zone from their Loan-A-Tool program...leave a deposit that is 100% refundable.    Also has an excellent puller for rear yokes.
