Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
90's 360 magnum
« previous
next »
Print
Pages: [
1
Author
Topic: 90's 360 magnum (Read 702 times)
Scat Pack Fever
Mopars Rule!!!!!!!! Always Have, Always Will
Full Member
Chrysler did it best!
90's 360 magnum
on:
January 17, 2010 - 08:28:47 PM »
Hello All! Will a 90's 360 magnum bolt up to a small block 4 speed e body bell housing? also, will it fit on the K frame? Thanks!
Last Edit: January 17, 2010 - 09:18:29 PM by Scat Pack Fever
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 90's 360 magnum
Reply #1 on:
January 17, 2010 - 10:46:36 PM »
the belhousing is the same , the engine mount could be different depending what it came out of , the Dakota used a different engine mount position
Logged
ShelbyDogg
Sr. Resident
Re: 90's 360 magnum
Reply #2 on:
January 21, 2010 - 11:45:13 PM »
The flywheel for a magnum 5.9 uses a different off-balance weight than an LA 360 so order the correct balance weight or flywheel if you do this.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
90's 360 magnum
