Author Topic: Removing upper control arm bushings  (Read 12563 times)
Offline 73EStroker
Re: Removing upper control arm bushings
« Reply #45 on: January 25, 2010 - 11:00:06 PM »
I just placed mine on a large vice plate with a short pipe about 3" long and a slightly larger diameter than the bushing outer ring - beat the pi$$ out of it with a 3lb hammer and out she comes , rust or no rust. Then i use the same pipe inside between the bushing holes and use the vice to press the new ones in. No problemo amigos. Same sort of process for u-joints as well. No expensive "use once in a lifetime junk" needed.
Barry (Salmon Arm)
Offline Samuelson1022
« Reply #46 on: May 31, 2010 - 05:39:51 PM »
Shadango, What press did you buy?
Offline shadango
« Reply #47 on: June 01, 2010 - 05:50:33 AM »
I bought a 12 ton press from harbor Freight......should be useful for other stuff in the future and it was cheap.  Although it does take up space in the garage....
