Author Topic: **More problems Popping Noise from the Brakes or Rear.  (Read 2109 times)
« on: January 20, 2010 - 05:05:11 PM »
    Binding..Popping, Seems to be coming from the wheels/brakes. Not as bad if I hold the brakes on.
   I first observed this a month ago one cold night when I moved the car from the cave to the house garage, after I got on the concrete it felt as if I was backing over something. Got out to check & found nothing so I continued on, one loud pop and a jerk & on we went till I started to turn about 10' later & all kinds of groaning & popping so I get a flashlight to see if something was hung up..nothing observed.  Over the last few days I had her up on jackstands , pulled the rear drums & all looks good, just a little surface rust from sitting. Rotated the wheels by hand & observed no binding of any kind so I ran the car on the stands & heard nothing unusual.
  Today backing the car out after abut 10' POP, went a little farther POP went forward & backward holding the brake on & had no issue until I tried to turn the car when the front acted like we were in gravel, kinda skidding & POP but this from the Right front. & it did not matter if I held the brake on or not.... Once more backing up & the rear POPPED, each time there is a sensation of being held back.
   A year or so ago I could move the car & had none of these issues, since then I had the rear end apart to install a limited slip diff but the brakes had already been done.
    Opinions?   Please  :1zhelp:
« Last Edit: January 20, 2010 - 05:09:32 PM by Bullitt- »
Offline Changin Gears
Re: **More problems Popping Noise from the Brakes or Rear.
« Reply #1 on: January 20, 2010 - 05:14:13 PM »
Backing up and turning with a Sure Grip can cause driveshaft/u-joint popping.  If you have a Sure Grip you could try the additive and also check for loose u-joints/ trans yoke.
« Reply #2 on: January 21, 2010 - 08:34:52 AM »
Wade, did you put sure grip additive to the unit?   Is the trans mount bolted down?  It doesnt do it on the stand when in gear?  Did you pulle the brake drums and run it in gear and look to see if the flanges  were turning without a wobble?  Im home soon if you need any help
« Reply #3 on: January 21, 2010 - 08:49:49 AM »
no additive yet...this is not  chatter but binding followed by a loud pop
tranny secure & no problems on stands...did not run with drums off.
looking forward to your return Alan....when do you want to swap in your stroker?
Offline farmboy70
« Reply #4 on: January 21, 2010 - 12:38:46 PM »
Try rechecking the brakes, if there is any oil residue in the drum or on the shoes it will make all kinds of noise. You may have a leaking axle seal.
Offline 72bluNblu
« Reply #5 on: January 21, 2010 - 01:09:20 PM »
Backing is also when the drum brake adjusters make their adjustments, if the adjusters are rusty they could be binding and releasing. Probably not, but I thought I'd throw it out there.
« Reply #6 on: January 21, 2010 - 04:42:00 PM »
Wheel bearings? :dunno: :clueless:
Offline RusTy/SE
  • Just havin' fun
« Reply #7 on: January 21, 2010 - 09:18:06 PM »
I had a similar situation on a 77 LTD i used to own. Turned out to be the front pads.
« Last Edit: January 21, 2010 - 09:21:15 PM by RusTy/SE »
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
« Reply #8 on: January 21, 2010 - 09:21:25 PM »
Hey Wade, did you make sure that the rearend is setting square in the perches and on the center pins? and that the ubolts are tightend good
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #9 on: January 21, 2010 - 09:46:51 PM »
I had a similar popping when moving back or forward when first starting to move,,flushed rear end stump (suregrip) and added proper fluid and additive and cured problem,,I could feel like the car jumped ,,could be felt through out entire car when popped
72rtchallenger
what happens in the garage
stays in the garage
« Reply #10 on: January 21, 2010 - 10:37:06 PM »
I'd-O-Never Thunk it..... Off to get some Slip additive...
 Thanks...Will report back.
« Reply #11 on: January 21, 2010 - 10:38:49 PM »
Think so but I'll see what I can ....Sounding like the additive may be the cure...gotta do that sooner or later anyway.
  • 72 to 70 clone
    • cardomain
« Reply #12 on: January 22, 2010 - 05:56:14 PM »
when mine caused the popping,,car had been sitting for a few years,,I had to drive it a time or 2 but problem went away
72rtchallenger
stays in the garage
Re: **More problems Popping Noise :) SOLVED (:
« Reply #13 on: February 20, 2010 - 06:58:20 PM »
     Alan, you must be psychic... While I don't think loose U-bolts were the issue they were not tight to spec, coulda swore I had torqued those down but obviously hadn't. And remember that tranny mount you showed me?  Think mine is toast as there is a definite shudder & noise when going from forward to reverse.
     Anyways  :woohoo: it appears the problem is solved, I put additive in the rear & ran it a while on jack stands, when I backed out I heard one or two pops but nothing like before, was able to turn the car without a hint of an issue.  Ran the car up  & down the driveway several times with no issues... I was testing out hoods carb also ...here's a video
  Thanks Guys.... Cuda-Challenger ROCKS :woo:
« Reply #14 on: February 20, 2010 - 09:18:28 PM »
Well i'm glad the car is finally getting closer for its first cruise around the block. You have been putting some long hours in on it.  If you want this spare mount I have, you can have it. Or if you need anything else, give me a shout
