Author Topic: Transmission vs Speedo Rading  (Read 2589 times)
Re: Transmission vs Speedo Rading
« Reply #15 on: January 24, 2010 - 11:43:23 PM »
I had my rear end (742 casting) built by Cass aka Dr. Diff,
MMMM bet you got a different rear gear now...
« Reply #16 on: January 25, 2010 - 04:41:23 AM »
One tooth will only mean 4-5MPH difference at hiway speed. If your speedo is reading fast, you need a speedo gear with more teeth, not less. I'll bet 33-34 is what you need Glennster.
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #17 on: January 25, 2010 - 08:29:13 AM »
Worlds first e-body trailer.    Severna Park, Maryland
Offline Glennster
« Reply #18 on: January 25, 2010 - 12:54:16 PM »
I'm pretty sure my old 7 1/4 rear end and my new 8 3/4 both have 323 gears....
« Reply #19 on: January 25, 2010 - 05:26:57 PM »
Sooo, if your rear tires are in the 26" range in diameter, then you need a 33-34 tooth gear, like I mentioned. Mine took a 34.
« Reply #20 on: January 25, 2010 - 10:51:15 PM »
Think I have a 33-tooth ...I'm gonna have to change to a 28....Want to swap?
Offline Glennster
« Reply #21 on: January 26, 2010 - 09:39:16 PM »
I think I'd like to swap, but let me get out with a GPS so I can check my actual speed before I commit to anything.
THANKS for the offer, I hope we can work out a win win deal!
Either way, I'll end up with a 28 or 29 that I can swap. If this thing is as far off as I think it is, you'll have you choice of a 28 or 29.
Offline the_engineers
« Reply #22 on: January 26, 2010 - 09:52:01 PM »
I've got one you can have.  PM me your address if a trade doesn't work out.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline Glennster
« Reply #23 on: January 27, 2010 - 06:14:47 AM »
THANK YOU Sir!
It might be a week before I car get the car out, the roads are packed with a little snow, salt and sand. Temperatures are supposed to stay low......
« Reply #24 on: January 27, 2010 - 07:46:46 AM »
Your inbox is full.  I should've been more clear.
"Hey Bullitt, I've got a 28 you can have.  PM me your address if a trade doesn't work out."
Sorry Glenn   :misbehaving:
Brooks
1971 'Cuda 360
« Reply #25 on: January 27, 2010 - 07:57:12 AM »
  Appreciate it, lets see what the Glennster comes up with, I'm in no hurry.
    BTW I confirmed I have a 33-tooth.
Offline Glennster
« Reply #26 on: February 02, 2010 - 08:14:57 PM »
 I should have gone for a test drive last night when the roads were half way clean, instead, we did a little reloading. Got to keep plenty of ammo around.
  I planned to get out for a test drive tonight but we got more stinking SNOW ! ! ! ! !   The roads are filled with salt, dirt and slush...AGAIN!!!
Please hang on to that 33, I suspect that's what I'll need, pray for warm dry weather ! ! ! ! ! !
Offline 70burntorangeT/A
« Reply #27 on: February 02, 2010 - 08:16:44 PM »
 :iagree: amen to that brother
66 f-100 black  240 straight 6  3 on the tree.....currently blown up :(
70 challenger burnt orange 440 727 3:23-weekend cruizer
« Reply #28 on: February 02, 2010 - 08:38:35 PM »
No rush here...not going anywhere.
Offline Glennster
« Reply #29 on: February 07, 2010 - 01:55:27 PM »
I got the Challenger out for a short spin, when the cars speedo say 60 mph, the TOMTOM (GPS) says 49-50mph. Sooooo, looks like I need that 33 gear, maybe more............
  It also looks like I'm running around 2,600 RPM's at 56 MPH, that sounds like too many RPM's for a 323 rear gear doesn't it? Could it be that I'm not getting a good reading because the torque converter is not fully engaged?
« Last Edit: February 07, 2010 - 02:01:09 PM by Glennster »
