Author Topic: Wheelwell Lip Trimming  (Read 1471 times)
nivvy
« on: September 13, 2004 - 09:57:37 PM »
Has anyone ever cut there wheelwell lip out a little for tire clearance????? good or bad??
8 Pack
Offline 360 'CUDA
Re: Wheelwell Lip Trimming
« Reply #1 on: September 13, 2004 - 11:24:11 PM »
Only a very little bit if at all
Too much and you will hate yourself in the morning :-\
Offline Grancoupe
« Reply #2 on: September 13, 2004 - 11:48:14 PM »
Yup, Had to fit the tire in there.
nivvy
« Reply #3 on: September 14, 2004 - 08:14:26 AM »
360 ??? why...strength or just hate to trim it...
8 Pack
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #4 on: September 14, 2004 - 07:42:39 PM »
I trimmed them on my `69 to fit some bigger tires,just be carefull not to go too narrow and cut past the spot welds and into the wheelhouse or the two pieces will separate but I suppose you could always reweld them together if you really needed that much room.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline 360 'CUDA
« Reply #5 on: September 14, 2004 - 08:29:13 PM »
Quote
360  why...strength or just hate to trim it...
8 Pack
Mostly I'm thinking resale value and overall appearance
Something that takes a little time to do and alot of time to fix
When you use the spring relo kit you have a wheel well that is almost 14 inches wide 8)
Try that in a nova or camearo
Offline GoMango
« Reply #6 on: September 16, 2004 - 06:55:53 AM »
What size tire are you going to run? The spring relo will help out. I am having to fix that problem on my Challenger except the whole lip is rolled in. Although a 11.5 x 29.5 M/T slick fit under the car w/ only the 1/2" shackle/hanger kit
This was done many yrs ago and I hate having to go back and fix :'(
70 Challenger R/T
(Back on the road--1st time since '96)
