Author Topic: difference in sb torque converter and bb torque converter  (Read 1290 times)
Offline challngd73
« on: January 23, 2010 - 05:08:56 PM »
Ok, my 727 tranny is fried, so my father was kind enough to give me his freshly built 727 tranny and new torque converter.  Only thing is, his 727 was bolted to his 1970 340, and my motor is a 1972 440.  I am assuming that I will not be able to use his torque converter, would I be correct with that assumption?  I can use the Tranny though, correct?  thanks again.
Jason
Re: difference in sb torque converter and bb torque converter
« Reply #1 on: January 23, 2010 - 05:22:28 PM »
Different bolt pattern to the engine I thought?
Offline challngd73
« Reply #2 on: January 23, 2010 - 06:46:04 PM »
what is a different bolt pattern, tranny or torque converter?
« Reply #3 on: January 23, 2010 - 11:35:25 PM »
the torque converter should work in both 727 trannies
the tranny case is a different size belhousing pattern small to big block
Offline challngd73
« Reply #4 on: January 24, 2010 - 12:39:30 AM »
so does that mean the tranny wont work?
« Reply #5 on: January 24, 2010 - 12:52:58 AM »
Ya ,small block and big block use different bolt patterns ( engine to tranny) It won't bolt up.
Offline challngd73
« Reply #6 on: January 24, 2010 - 12:57:11 AM »
well sheot.
