B Body Rear exchange
Author Topic: B Body Rear exchange  (Read 1921 times)
nivvy
« on: September 13, 2004 - 10:11:51 PM »
If I get an empty B body housing...will it accept at the guts/ brakes of my e body rear end???
8 Pack
Plum6Pak
Re: B Body Rear exchange
« Reply #1 on: September 13, 2004 - 10:52:51 PM »
 :) Yes and no, the differential housing will, the brakes will, the axles won't.  :D
nivvy
« Reply #2 on: September 14, 2004 - 08:12:32 AM »
Cool I was getting new axels anyway....
Offline GoMango
« Reply #3 on: September 22, 2004 - 09:13:06 PM »
How come the brakes will not work ???
70 Challenger R/T
(Back on the road--1st time since '96)
Plum6Pak
« Reply #4 on: September 23, 2004 - 12:02:14 AM »
Sorry GoMango, that's my fault the way I worded it. The only thing that won't fit is the axles.  ;D
Offline GoMango
« Reply #5 on: September 23, 2004 - 06:43:39 AM »
Now that I read the quote, I see you had "will fit" in there :-[  Good thing about the b-body housing is it will be a little narrower for more tire clearance ;D
70 Challenger R/T
Offline 1973challenger360
« Reply #6 on: September 23, 2004 - 11:49:16 AM »
The sway bars wont fit as I under stand
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #7 on: September 23, 2004 - 04:45:57 PM »
I would think that the rear sway bar should be fine.  The B-body housing mounts are less than an inch closer to the center of the housing on each side.  This will only slightly change the angle of the end links.  I might be missing something there though.
Offline 2000gt
« Reply #8 on: September 26, 2004 - 01:37:13 PM »
I don't mean to thread hijack but I've giot a related question, are theree any performance differences between the b-body housings, for example, I got one out of a satellite and it has the puny 741 center section in it.  I will be putting my 489 center section in it but was wondering if there were any difference in the actual housings, or are they all the same ie axle diameter, bearing size, etc.
Plum6Pak
« Reply #9 on: September 26, 2004 - 01:56:39 PM »
The 8 3/4 axle housings or banjo's as they are called are all the same as far as how they are built, the only difference is in the dimensions as far as the different body styles A B C E etc.. The differential housing or drop out or carrier or chunk assembly, 741, 489 and 742 housings will fit into any 8 3/4 housing. Hope that makes sense. The 742 is the toughest although some would argue the 489 is. The 489 has a tapered pinion but the 742 is straight.  :D
Offline 360 'CUDA
« Reply #10 on: September 26, 2004 - 02:00:12 PM »
The pinion gear size is the main difference
That 741 has the 1 3/8  pinion gear and is not recomended for high performance use
(I'll bet ya it's still stronger then the GM 10 bolt)
As far as outside dimentions it's about the same
The big difference you might need to address is the U-joint size.
You may need to buy a new one to get the 489 case to work with your driveshaft
Offline 2000gt
« Reply #11 on: September 26, 2004 - 02:08:11 PM »
Alright, thanks you guys, thats kind of what I suspected but when you read the Yearone catalogue it kind of leads you to believe that the actual housing or 'banjo' are different ie different bearing size, etc depending on what type of center section they came with ie 489, 741. obviously I know they are different widths, thats why I put one in ;D I will be using the 489 casing in the b-body rear housing and the driveshaft wont be a problem as I don't have one yet :P.  Thanks again guys, it seems like I always have all the questions and you guys have all the answers, when that going to change?
Plum6Pak
« Reply #12 on: September 26, 2004 - 02:24:32 PM »
 :o I usually ask more questions than I ever answer. I know a lot less than I know! hehe  ;D
