Author Topic: Need rear sway bar length measurement?  (Read 623 times)
Offline GoodysGotaCuda
« on: January 24, 2010 - 12:59:04 AM »
I am looking at the salvage yard for a sway bar to retrofit to my barracuda. I was wondering if anyone had a bar or knew the length of the factory rear sway bar? :cheers:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline JayBee
Re: Need rear sway bar length measurement?
« Reply #1 on: January 24, 2010 - 10:58:27 AM »
I've got 2 of these in my basement right now. Between connecting link centers one bar is 46 1/4" and the other is 46 1/2". Obviously one of them is slightly bent but that should give you an idea. I'll be more than glad to give you any other dimensions if you want.
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #2 on: January 24, 2010 - 11:37:46 AM »
should get me started. Thanks!
1976 Dodge Warlock
Offline JayBee
« Reply #3 on: January 24, 2010 - 11:50:57 AM »
You're welcome, I wish one of them wasn't bent though.
John
2014 Toyota Avalon
Offline Aracer
« Reply #4 on: January 24, 2010 - 02:18:07 PM »
 you should measure at outside of the first bend, after the forged 0 ends. It looks like the real thing, and there is nothing that looks similar, other than the after market. you may find the holes in the frame pre- drilled for the factory bar.  I found one for an a-body with the same attachment points on the frame.
They claim less un-sprung weight. And poly bushings, $ 300+, yipes it was $130 complete for E-body, at a mopar parts counter for replacement parts in 1976.
I love it for centering the car over the axle.+ stability under acceleration.
