Author Topic: 74 challenger front disc brake anti rattle spring  (Read 581 times)
Offline femtnmax
« on: January 24, 2010 - 08:35:10 PM »
Replaced the calipers with Wagner rebuilds.  Kits came with new caliper pin/bolts and spring with hooks on each end to connect to pins, but how and where do they go??  The older model challys had spring clips that went on the ends of each pin/bolt, so thats easy to understand.   The new spring clips have me stumped.
Phil
Re: 74 challenger front disc brake anti rattle spring
« Reply #1 on: January 24, 2010 - 11:15:08 PM »
the hook into the bolts inside the caliper & wrap around the outside of the caliper to go across the outside of the caliper
a pic is worth a 1000 words  :banghead:
