Author Topic: Tips needed: Replacing driver and passender window window beads/rubber  (Read 485 times)
Offline DocMel
Folks  I have nwe beaded window seal set that goes on top of the door on my cuda:  I would appreciate any hints to make the installation a little easier
I have the door panel off, and removed the lower window bumper, and that almost let me lower the glass enough to remove the old bead:  Almost, but not quite........
How can I get better access to remove the old beads?
Offline the_engineers
Re: Tips needed: Replacing driver and passender window window beads/rubber
« Reply #1 on: January 24, 2010 - 09:36:38 PM »
Remove the shoulder bolts that attach the windows to the regulators.  That will let the window drop (literally if you're not careful) to the bottom of the door.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
