Author Topic: Stripped Door Panel Screw Holes  (Read 1785 times)
Offline the_engineers
« on: January 24, 2010 - 09:34:46 PM »
Most of the holes for my door panels are stripped.  Is there a recommended way to repair this?  I'm tempted to put 8-32 nutserts in the door and use SS truss-head screws instead.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Alaskan_TA
Re: Stripped Door Panel Screw Holes
« Reply #1 on: January 24, 2010 - 09:38:40 PM »
From the backside, gently tap the crown flat with a tiny hammer. Not easy to do for some of them.
You can poke a small nail with a head through from the backside then chuck it up in an old-fashioned dent puller. Be gentle. As the crown flattens it will make the hole diamater smaller. In most cases not much is needed.
Offline BIGSHCLUNK
« Reply #2 on: January 24, 2010 - 09:39:10 PM »
j-b weld a few clips inside thw door itself... the flat ones... forget the name...
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #3 on: January 24, 2010 - 09:40:36 PM »
Flat speed nuts?
Brooks
1971 'Cuda 360
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: January 24, 2010 - 09:42:16 PM »
Small plastic anchors will work as well.
Tom :cheers:
Tom
Offline BIGSHCLUNK
« Reply #5 on: January 24, 2010 - 09:44:42 PM »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline don340-4
« Reply #6 on: January 24, 2010 - 09:53:17 PM »
I used Alaskan_TA nail method worked perfect & was able to use the original factory screws, chrome phillips head w/the sleeve to prevent crushing the panel
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
« Reply #7 on: January 25, 2010 - 01:59:19 PM »
Quote
That's what I've heard as well.  Just get some of those small anchors that you would use to attach a picture to a wall where there is no stud.
Otherwise you can weld them up and redrill the holes.
« Reply #8 on: January 25, 2010 - 02:41:47 PM »
Has anyone tried nut-serts?  I have a Marson thread riveter which may be one of the best inventions, ever.
Brooks
1971 'Cuda 360
Offline 4drbrnko
« Reply #9 on: January 25, 2010 - 03:39:06 PM »
A hand held rivet gun works good for this too.  :thumbsup:
<-------<<<  Clickylinks..... My vehicles
« Reply #10 on: January 30, 2010 - 07:36:18 AM »
I like the idea but not tried it. The only problem I can think of would be the 1/16" (approx) thickness of the head of the nut-sert/riv-nut. I'm thinking it would leave a small gap between the door and door panel?
