Author Topic: 8 3/4 Rear End and 340 Engine  (Read 3988 times)
Offline 1970ChallySE
« on: January 26, 2010 - 02:42:38 PM »
I already mentioned this in another thread under Suspension, but does anyone know if an 8 3/4 Rear End from a B-Body will fit correctly into an E-Body (specifically a Challenger)?
I am also looking for an 8 3/4 Rear End.  Can anyone help?
I would also be interested in a 340 as well.
Offline farmboy70
Re: 8 3/4 Rear End and 340 Engine
« Reply #1 on: January 26, 2010 - 06:55:55 PM »
You can use a 68-70 B-body in a Challenger with offset spring mounts.
Dr Diff sells a kit for this.  In these pictures you may be able to see the offset mounts.This is a 70 b-body width Strange Dana.
Dave
« Reply #2 on: January 26, 2010 - 06:59:15 PM »
The B-Body rear is shorter, that's why you need the offsets...But yes, it will fit in an E-body.
Offline bb71challenger
« Reply #3 on: January 26, 2010 - 07:12:12 PM »
Yep, it is one inch narrower. Gives you slightly more room for bigger meats   :burnout:
*Brett*
Offline the_engineers
« Reply #4 on: January 26, 2010 - 09:06:44 PM »
Where are you?  I have a couple of 340 motors.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #5 on: January 26, 2010 - 09:41:32 PM »
Dave
How much does it offset? Can originals be fabbed? Any pics of mount up close?
Offline farmboy70
« Reply #6 on: January 26, 2010 - 09:49:49 PM »
I just checked my pictures, it looks like I didn't take a good shot of the mounts. If no one posts a picture I can get one tomorrow.
Dave
Offline ShelbyDogg
« Reply #7 on: January 28, 2010 - 10:34:44 AM »
Dr. Diff's kit is around $180. You can use a stock e-body rear but the spring perches will have to be cut off then rewelded 1" towards the inside. Using a 68-70 b-body rear, allows you to just drop it on to the moved springs without any welding.
Rob
Offline farmboy70
« Reply #8 on: January 28, 2010 - 10:45:33 AM »
These arre the left side, tough to get pictures where the car is right now. If you need better ones I can put it on the rack to get them.
Dave
« Reply #9 on: January 28, 2010 - 09:46:06 PM »
Thanks for the pics Dave.   :2thumbs:
I was helping Challenger500 today. He just bought a Dana 60 and needed me to haul it over to his place. After dropping it off, I got to see the offsets up close in person on his car.
He's changing to a 4 link possibly so he said he might sell me his set up.
Offline farmboy70
« Reply #10 on: January 28, 2010 - 09:50:56 PM »
Sounds like a good deal :thumbsup:
Dave
Offline Aracer
« Reply #11 on: February 19, 2010 - 02:05:37 PM »
I would like to add that the offset hangars supplied by Mopar are only .8".       Dr.Diff's are 1" and reduce the stress you see on the rubber bushing.  I used Prothane #4-802-BL bushings instead.         Nice color car!
Offline jvike
  • Pro-Touring Cuda
« Reply #12 on: March 08, 2010 - 05:44:34 PM »
I have an B-Body 8-3/4. On My axle the leafspring shoes on the axle had been moved to fit. Now I have an XV Level II setup. Did use the Dr.Diff hangers to move the trailing arms inwards. Hopefully I'll be able to fit 18x12 with 335's
