Author Topic: Vapor Separator/Fuel Filter  (Read 1353 times)
Offline 70challengersix
« on: January 26, 2010 - 03:31:36 PM »
I have a question regarding the vapor separator/Fuel Filter use on a 70 challenger 44 six pack setup.  I have seen cars advertised as numbers matching with a fuel filter located betweent the fuel pump and vapor separator using rubber fuel hoses.  I have also seen cars without the fuel filter installed with the line running from the carb to a point near the separator and then connected with a short rubber hose.
I have read where the strainer on the sending unit in the tank in addition to the separator and an inlet screen on the carb acts as a filter and therefore one is not needed.  Can anyone weigh in on this and advise what is correct.
Re: Vapor Separator/Fuel Filter
« Reply #1 on: January 26, 2010 - 06:50:36 PM »
I can't say what is correct, but I would not run without a fuel filter. That strainer, or sock on the sending unit is only good for larger debris. I would think your carb screen would get plugged up much quicker than a fuel filter would.    :2cents:
Offline farmboy70
« Reply #2 on: January 26, 2010 - 09:54:10 PM »
There is suppost to be a screen in the vapor seporator also. I have never cut one open but read it somewhere. :dunno:
« Reply #3 on: January 26, 2010 - 10:41:55 PM »
http://www.dodgecharger.com/forum/index.php/topic,4414.0.html
This link explains it- it appears as though the separator acts as th filter.
Offline 73Chally
« Reply #4 on: January 27, 2010 - 08:56:41 AM »
I ran just the vapor separator on mine with the 6 pack, and had no problems.  The last time we had the carbs off, we did not se anything in the filter traps on the carbs, so no issues.
Offline Supercuda
« Reply #5 on: January 27, 2010 - 09:18:09 AM »
The vapor separator is a fuel filter- it has a filter element in it. In later years, the filter/vapor separator was installed on practically everything. For numbers matching, you need the one from the original setup, but there are replacements out there for us to run on our drivers.
