Author Topic: 71 Cuda "T" shift handle (Auto Trans) bolt on (replace) the 1970 style knob  (Read 978 times)
Offline DocMel
Will a T handle from a 1971 Cuda bolt right onto a 1970 style ball/button shifter?
Offline coupman35
  • It going to be FUN
Id say no the T  shaff handale rod  is flat and the ball one is round .
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
Another '70 Only thing in E-Bodies.   :pullinghair:
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
The "T" handle may not fit, but the whole thing will change out. I put a 70 style ball shifter in one of my 71's that had the "T" handle.
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
no ,as the others have said it won't fit. One is round (1970) and the other is rectangular (71-74)
 I have a 70 Challenger  I have both styles of shifters. I chose to install the 71-74 style as I just liked it better with the aftermarket shifter I chose.
You can find an entire assembly to replace but I'm sure the chrome housing is going to be pitted.  You can buy all new components from BE&A.  They sell both styles.  All you would have to do is get the 71-74 black shifter plate with the square hole in it.  The replacement housings use small bolts to hold the halves together instead of the fatory rivets.
BE&A might also have the "shift gate" indicator insead of the "slap stick" one too if your car is equiped that way.
